Volume control gone.
  1. Posts : 1
    You wake up one morning and your volume control icon is not in the taskbar. You get into the customize box and the volume control has no icon. In the system controls box, volume control is grayed out and you can't turn it on there either. Any ideas?
  2. Posts : 72,051
    Hello Vinlibassi, and welcome to Seven Forums.
    You might see if you may be able to fix the volume icon by seeing if enabling the volume icon using the tutorial below.
    System Icons - Enable or Disable
  3. Posts : 7,055
    Windows 7 Home Premium 32 bit
    OK. There are many possible solutions to this problem depending upon what exactly causes it. But let me start with this as the most probable.(may not be too.:) ) So its gonnabe a hit and try.
    Some corrupted .dll files in the System32 folder can cause this vanishing speaker icon. Atleast one user found it to be. The solution is to replace the corrupt .dll files. But first one has to find whether there are any.
    Start > All Programs > Accessories > Command Prompt > Right click Run as Administrator.
    Type sfc /scannow after the command prompt and press Enter
    When finished open the sfc log file at C > Windows > logs > CBS > CBS.log
    Search for anything "cannot repair"
    Report if there is any and then the procedure to copy the .dll files from the Windows 7 Installation Disk can be taken up. Some other expert can help you on this if I go missing. :)
    If this is not the case other solutions can be rolled out.
    EDIT:SFC - see Brink's tutorial here
