Sound issues when using Sonar 8.5 with x fi fatality champion card
viennak8
5:50 AM
Hi folks,
I have posted this problem on another forum (a harware forum) but thought I would post here as my problem is to do with Windows 7 Professional 32bit.
My specs are (as near as I can remember)
asus p5n73-am motherboard with onboard NVIDIA nForce 630i graphics
4GB RAM
Creative x fi Fatality Champion sound card
I have a clean install of Windows 7 32 bit and Sonar 8.5 and have updated the BIOS and all drivers (both Windows and Sound Card). I have also clean installed Windows 7 and accepted no updates and I have uninstalled the nvidia graphics driver and accepted a standard VGA adapter - all with no difference
On starting SONAR and arming an audio track I have a terrible clicking sound which increases in rate the lower I move the latency slider. It makes the track unusable. I have tried using WDM and ASIO with no difference.
Please let me know if any more info is required
I'd be grateful for any input
Regards
SOS
Windows 7 Professional 32bit4GBNVIDIA nForce 630i
asus 5p73n-am
4GB
NVIDIA nForce 630i
I have Sonar X1 (and 8.5.3). I had an Xfi card installed but it interfered with my Focusrite Saffire Pro 40 recording interface unit and I have to remove it.
ASIO is the preferred over WDM.
Just to see if it's something with Sonar or something with the card or Windows. If you don't have it, download the free Audacity recording program and try that and see if you get the clicks with Audacity. If you do, that points it back to the Xfi or something else in the PC. Audacity: Free Audio Editor and Recorder
You can post on the Sonar forum too, SONAR Producer and Studio
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
