windows 7 choppy sound after recording with synth
  1. Posts : 9
    Connecticut
    I am running windows 7
    dell inspiron 570
    64 bit 6gb ran
    amd athelon x3
    emu 0404 pci sound card
    my sound on playback after recording music from my synth comes out choppy. I have disabled every service i don't need disabled the realtex and amd high def audio check the speaker setting adjusted recording levels and still i get choppy sound. I just got this computer two weeks ago. any help would be great
  2. whs
    What is the filetype of the recorded music.
  3. Posts : 9
    Connecticut
    file type
    wav i record into the acoustica mp3 audio mixer
  4. whs
    Hmm, sorry but I am a bit confused. Are they .wav or .mp3 or where they .wav originally and are now .mp3. Another possibility would be .mp3 files with a .wav header.
  5. Posts : 9
    Connecticut
    Ok let's try this. I play from my synth via a vst on my computer. I record the out put to acoustica and it saves it as a wav. I should also mention that windows media player and the internet and movies all sound fine
  6. whs
    So they are .wav files. Those are lossless (but massive) and should play fine. As an experiment convert them to .wma or .mp3 with Format Factory and see whether that works better.
  7. Posts : 9
    Connecticut
    thought of that but they retain their ultra choppy state i'm afraid.
  8. whs
    Did you actually try it - if yes, it must be in the recording and there is probably little you can do about it.
  9. Posts : 9
    Connecticut
    the thing of it is I think it's some kind of conflict but I an out of ideas of where to look
  10. whs
    Choppyness usually comes from a driver problem. You can check your Latency with this program and see whether you have any red bars (have the ,wav files running during the check). If there is a problem, the latency checker may give you additional info.
