I do not see a spdif interface
danlnad
12:21 PM
I plugged in my HDMI cable to my laptop. I get only video, without sound. I discovered that i have to select the S/PDIF settings. BUT, i only see the "speaker" settings. I have selected and deselected the "show disabled devices", to no avail. What am i doing wrong? I am trying to get the sound to play through my HDMI cable. I have googled this problem and found solutions with all of them being that i have to select the S/PDIF...and i don't even have it listed as an option and no way of knowing how i can get it to show up.
I have an ASUS UL80V laptop with a windows 7 OS. My audio works fine other than the S/PDIF issue.
I must be doing something wrong, any help will be appreciated.
Asus UL80V, 64 bit, windows 7
HDMI Port (the ASUS UL80V )
HDMI (High-Definition Multimedia Interface) is an uncompressed all-digital audio/video interface between any audio/video source, such as a set-top box, DVD player, and A/V receiver and an audio and/or video monitor, such as a digital television (DTV). Supports standard, enhanced, or high-definition video, plus multi-channel digital audio on a single cable. It transmits all ATSC HDTV standards and supports 8-channel digital audio, with bandwidth to spare to accommodate future enhancements or requirements.
For models with both the integrated and discrete graphics cards, the HDMI output is available only when you select the discrete graphics card mode.
Windows 7 Ultimate 32bit
How do i select the discrete graphics card mode?
HDMI incorporates its own audio device to carry audio along with the video. It doesn't use your laptop's onboard audio.
If you go to Control Panel -> Sound, you should have two audio devices listed under the Playback tab. Rightclick the one that says HDMI and set it as the default device. You should then hear all sounds through the HDMI connection (and no longer from the laptop's speakers).
Windows 7 Professional SP1 32-bitIntel Core 2 Duo E6600 2.4GHz4GB DDR2-667 (4x1GB in dual-channel config)nVidia GeForce 9800 GT
Custom-built
Asus PL5D2
Creative X-Fi XtremeMusic
Acer P236H
1920x1200 (DVI)
OCZ SSD Vertex Plus 60GB SATA (Firmware 3.55), 64MB cache
Hitachi HD321KJ SATA, 320GB, 7200rpm, 16MB cache
Antec TruePower 2.0
Cooler Master Centurion
Too many fans
Standard
Microsoft wireless optical mouse
AT&T U-verse (18mbit/sec)
Other devices:
Compaq CQ-60 laptop
Google Nexus 7 (2012) tablet
Nvidia SHIELD tablet (US/LTE)
Hardkernel ODROID-XU single-board computer (Samsung Exynos 5420)
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
