Windows 7: Sigmatel 97XX C-Major Audio Driver Help Needed!
07 Aug 2009   #1
SOLVED: Sigmatel 97XX C-Major Audio Driver Help Needed!
I have an older P4 2.8ghz Dell Dimension 3100 that currently has Windows 7 installed. Apparently the driver is the Sigmatel 97xx C-Major audio according to support.dell.com - the first thing I tried was the Windows Vista driver listed on Dell's site. Unfortunately that did not work. The driver appears to be installed and I have a sound device however I have no output through the speakers. I'm sure it is a driver related issue.
The device enabled, the speakers work and are hooked up properly.
Any ideas where I can find a Windows 7 driver for the Dimension 3100 using the onboard Sigmatel 97XX?
07 Aug 2009   #2
Window 7 build 7600, Xp pro(VM)
West Bengal
Welcome to SF.
Have you tried downloading it via windows update?
07 Aug 2009   #3
Quote   Quote: Originally Posted by septprince View Post
Welcome to SF.
When using Windows Update it installs something called High Definition Audio Device which still does not work.
07 Aug 2009   #4
Well let me just state I think I fixed it...
I removed all drivers. Ran Windows Update on that driver. It installed the High Definition Audio Device - I went into playback devices and made sure the speakers were enabled and voila! It works - Well thanks I guess heh!
07 Aug 2009   #5
Well now the only other issue I have is with my Line 6 Guitar Port not working. I should probably make a new thread for that issue.
07 Aug 2009   #6
West Bengal
If you problem solved please ask a mod to mark the this thread as solved..
 Sigmatel 97XX C-Major Audio Driver Help Needed! problems?
Similar help and support threads for: Sigmatel 97XX C-Major Audio Driver Help Needed!
Inspiron E1705/9400 Sigmatel 9200 HD Audio Driver Sound & Audio
Solved Sigmatel/IDT audio driver stac9271d Drivers
sigmatel c-major audio Sound & Audio
Problem with Sigmatel Audio Driver for Inspiron 1525 Sound & Audio
Sigmatel Stac92XX C-Major HD Audio Driver Sound Problem Sound & Audio
