Windows 7: Genius Sound Maker Value 5.1 Crackling Sound
26 Nov 2011
nejcjanhar
32bit
Hello,
I upgraded my Win XP to Win 7 like 1 month ago.
Downloaded all drivers (from their sites) updated them... then i open WMP 11 and start playing some music. After listening to that i heard some weird sound lag, I believe its called crackling. I searched on internet found some solutions, but none worked and none was for mine sound card.
This wasn't happening on Win XP.
Oh and if i have older version of driver it works way batter (only hear crackling when my cpu goes up to 1000MB (100%) ), but then my Microphone goes really quiet like I disabled microphone boost.
Hope you understand my problem.
OTHER SYSTEM SPECS (My PC is old):
"Windows","Windows 7 Home Premium Edition (Build 7600)"
"Internet Explorer","9.0.8112.16421"
"Memory (RAM)","1023 MB"
"CPU Info","Intel(R) Pentium(R) 4 CPU 2.80GHz"
"CPU Speed","2802,0 MHz"
"Sound Card","Speakers (C-Media PCI Audio Dev)"
"Display Adapters","NVIDIA GeForce FX 5600 | NVIDIA GeForce FX 5600 | RDPDD Chained DD | RDP Encoder Mirror Driver | RDP Reflector Display Driver"
"Monitors","1x; Generic PnP Monitor | "
"Screen Resolution","1024 X 768 - 32 bit"
"Network","Network Present"
"Network Adapters","VIA Rhine II Fast Ethernet Adapter | Hamachi Network Interface"
"CD / DVD Drives","2x (D: | E: | ) D: _NEC    DVD_RW ND-2500A  | E: DTSOFT  BDROM"
"Ports","COM1 LPT1"
"Mouse","5 Button Wheel Mouse Present"
"Hard Disks","C:  149,0GB"
"Hard Disks - Free","C:  71,0GB"
"USB Controllers","5 host controllers."
"Firewire (1394)","Not Detected"
"Manufacturer *","Phoenix Technologies, LTD"
"Product Make *"," "
"AC Power Status","OnLine"
"BIOS Info","AT/AT COMPATIBLE | 06/08/06 | ACRSYS - 42302e31"
"Time Zone","Srednjeevropski standardni čas"
"Battery Status","No Battery"
"Motherboard *","P4M800CE-8237"
"SM BIOS","6.00 PG"
26 Nov 2011
nejcjanhar
32bit
Here Two Pictures from two programs (DPC Latency Checker V1.3.0 and LatencyMon), while playing music.
The results are pretty much the same.
Genius Sound Maker Value 5.1 Crackling Sound-dpc-latency-checker-v1.3.0.png   Genius Sound Maker Value 5.1 Crackling Sound-latencymon.png
28 Nov 2011
nejcjanhar
32bit
Anyone???
 Genius Sound Maker Value 5.1 Crackling Sound problems?
Similar help and support threads for: Genius Sound Maker Value 5.1 Crackling Sound
[Sound crackling ] VPN client messed up my sound settings Sound & Audio
Sound Crackling/ Fuzzy Sound & Audio
Crackling Sound Sound & Audio
Crackling sound and System lag Sound & Audio
Crackling and dragging sound Sound & Audio
