Windows 7: Need sound to come out through 2 devices at the same time
30 Nov 2011   #11
Corazon
Windows 7 Professional SP1 32-bit
Quote   Quote: Originally Posted by ambiente View Post
Hello,
I need sound to come out through my hdmi AND the headphone jack at the same time.
Under playback devices I have AMD HDMI sound and Realtek High Definition audio. Both devices work when I check them - just cant get them both to work at the same time?? Help!
Exactly why do you need it to be this way?
You could plug in a headphone set to whatever's plugged into the HDMI output (I'm guessing a TV), or you could simply stay with the Realtek sound device and connect your PC to an amplifier with speakers, and again use the headphone jack on the amplifier at the same time.
I don't really think you have to have both audio devices enabled at the same time.
30 Nov 2011   #12
ambiente
7 64bit
Thanks for all the replies...
The hdmi goes to my reciever/tv in a different room, the stereo jack goes to my computer speakers. Want to be able to play the same sound in both rooms at the same time...
30 Nov 2011   #13
rubyrubyroo
MS Windows 7 Home Premium SP1 64-bit (Family Pack Lic.) Upgrade
does your HDTV have surround sound speakers or do you use the built in factory speakers? or maybe jst 2.1 surround?
Does you HDTV have a 1/8" (3.5mm) phono jack input and/or output? (that is like a headphones plug hole like the ones on the back of computers for the basic speakers or mic)
Using two audio devices the same time...
How can I use both my Usb headset and the 3.5mm phono jack speakers playing at the same time and even two microphones one that is USB and other that is 3.5mm jack? How about using two 3.5mm jack devices?
scratching sound even if all sound devices disabled
Hi, In my headphones, I ear a constant scratching sound even if all sound devices are disabled (playback and recording). Where can comes this sound ? What can I try ? Regards,
Sound skips after some time (tried diff. sound cards)
Hello, I used to have Vista on this computer and didn't have audio problems. I've upgraded to Windows 7 and use the latest drivers available for my sound card (Striker 7.1). I have also tried not using these drivers and instead using a USB sound card (Sennheiser that comes with one of their...
Can I Listen To Audio On Two Devices At The Same Time?
so when i had xp i could launch WMP with my speakers and change to output to my headphones. the music would play on the speakers and i could play a game on my headphones at the same time. now it changes the moment i switch default audio outputs.
two audio devices at the same time
hi together.. i have three audio devices on my system. a Creative SB X-Fi, a Logitech Z-10 USB Speaker and a Trekstor SoundBox USB Speaker (wireless). I would like to use the Logitech Z-10 USB Speaker or the Creative SB X-Fi and the Trekstor SoundBox USB Speaker (wireless) at the same time...
M-Audio Audiophile 2496 sound hanging/stuttering from time to time
hey guys, i just bought a new M-Audio Audiophile 2496 soundcard to enjoy great sound in a foobar2000 + flac combination. i've successfully installed the Vista 32bit drivers in compatibility mode and everything worked fine until then. after starting to listen to music, i've experienced that...
