Need sound to come out through 2 devices at the same time
ambiente
9:02 PM
Hello,
I need sound to come out through my hdmi AND the headphone jack at the same time.
Under playback devices I have AMD HDMI sound and Realtek High Definition audio. Both devices work when I check them - just cant get them both to work at the same time?? Help!
7 64biti5
hp
7 64bit
i5
Welcome to Windows Seven Forums.
Generally speaking, connecting headphones to the front sound port will cut off the sound output from the rear sound port.
A simple way round your problem would be to connect a 3.5mm stereo plug to 2 phono sockets adapter to your rear sound port enabling you to use your speakers and headphones at the same time.
3.5mm Stereo Plug to 2 Phono Socket
HP Pavilion Elite 495UK
Windows 7 Ultimate SP1 64-Bit
Intel Core i7 870 @ 2.93GHz
MSI 2A9C (CPU1)
HP2310i
460W
HP Elite
Air cooled
Logitech Wireless M180 mouse
2Mb
The headphone jack, which is on the rear, is connected to my computer speakers - the hdmi is connected to stereo - need both to play at the same time
7 64biti5
hp
7 64bit
i5
impossible afaik
Microsoft Windows 7 Home Premium 64-bits 7601...Intel(R) Core(TM) i3 CPU M 370 @ 2.40GHz4,00 GBATI Mobility Radeon HD 5400 Series
ACER ASPIRE 5742G
Acer Aspire 5742G
4,00 GB
WDC WD5000BEVT-22ZAT0
Hi Ambiente!
Just curious what the reason for both used at once is meant to accomplish. If I may ask?
Mike:)
MS Windows 7 Home Premium SP1 64-bit (Family ...AMD Phenom II X6: Black Ed 1090T - AM3 / 3.2G...2 dual ch sets OCZ DDR3 PC3-10666 Platinum 13...Onboard
Custom self build - Desktop
MS Windows 7 Home Premium SP1 64-bit (Family Pack Lic.) Upgrade
AMD Phenom II X6: Black Ed 1090T - AM3 / 3.2GHz / 8MB
Biostar TA790XE3
2 dual ch sets OCZ DDR3 PC3-10666 Platinum 1333MHz 8GB total
Onboard
Onboard 5.1 channel HD
SyncMaster "Legal-sized" LCD (rotatable)
unknown (8.5"x15")? pixels are not known
HDD1: WD RE3 Enterprize [p/n: WD500ABYS-NDW]
________SATA-II (3Gb/s) 500GB/7200rpm/16MB
HDD2: Deskstar 7K1000.C [p/n: HDS721010CLA332]
________SATA-II (3Gb/s) 1TB/7200rpm/32MB
Antec 900W mATX 20+4 w/6-8SATA;2MLX;4x6(+2)PCIe[p/n HCG-900]
Mid 10-bay tower - free space design interior & well vented
CPU HS cooler, 14.5" Case-sysfan1, dual sysfan2, exhaust
Blue Star Ergonomic - ps/2
LED coorded w/v. roller wheel - ps/2
GbLAN 10/100/1000 & WLAN - on T1 (Peer Network)
Harmon-Karden speakers (L,R @ sub)
APC (Lead/Acid Batt backup UPC+Surge protector+etc)
Sony DVD SATA(300) - RW DVD/CD SATA-II(300)
They probably want TV sound (via HDMI) and to have PC sound both. Can't do it as you can only have one default playback device, either have the HDMI sound or the PC "Speakers".
rubyrubyroo, you and I are close.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
@ Fireberd - I know, but I still check out reasoning , it sometimes helps, under certain circumstances..... BTW are you using Pro Tools or Sonar Fireberd?
Mike
Biostar TA790XE3
Onboard
I'm using Sonar X1c but I recently bought Pro Tools MP9 at the GC on Hillsborough and working on learning it.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
@fireberg - say, for the sake of argument, that the OP wants to do what you mentioned, BUT it's only when asked for more info that you learn their Graphics card has a unused DVI interface, and they were using the factory stereo internal speakers on the TV, not realizing that they could simply pull the HD vid thru a DVI-to-HDMI cord and enjoy the same stereo sound from a rear 1/8" phono stereo jack out and a similar male-to-male 1/8" (3.5mm) phono cord, assuming there is a 1/8" phono audio in option on the HDTV as most have. most audio cards will allow the front jacks to be bussed separately, from the rears by a mere checkbox, and you would only need one device (i guess its technically 2 but it allows it, front=headphones device, rear=speakers device). Tweak a few sliders pots in the appropriate device audio tabs so the sound is routed correctly and job done. Even easier if the purpose was to play the same sound through both the speakers and the headphones, because say...i dunno someone is has a hard time hearing the TV, or likes to use a headphone unit with a built in volume control potentiometer, because the TV's too loud for them usually! same setup , just not onscreen slider tweaking! easy-peasy. right?!:sarc:......:)
I'm sure I'll be wrong but, hey, I heard "impossible" a few posts up and became intrigued enough to ask "why" at least!
Sincerely,
Mike :D
Biostar TA790XE3
Onboard
so ambiente, can you explain what you want to do exactly, and remember i cant see your house, so you need to answer questions as if I dont know what you have as far as equipment or whats in your mind.
Sincerely,
Mike:D
Biostar TA790XE3
Onboard
Hello,
Exactly why do you need it to be this way?
You could plug in a headphone set to whatever's plugged into the HDMI output (I'm guessing a TV), or you could simply stay with the Realtek sound device and connect your PC to an amplifier with speakers, and again use the headphone jack on the amplifier at the same time.
I don't really think you have to have both audio devices enabled at the same time.
Windows 7 Professional SP1 32-bitIntel Core 2 Duo E6600 2.4GHz4GB DDR2-667 (4x1GB in dual-channel config)nVidia GeForce 9800 GT
Custom-built
Asus PL5D2
Creative X-Fi XtremeMusic
Acer P236H
1920x1200 (DVI)
OCZ SSD Vertex Plus 60GB SATA (Firmware 3.55), 64MB cache
Hitachi HD321KJ SATA, 320GB, 7200rpm, 16MB cache
Antec TruePower 2.0
Cooler Master Centurion
Too many fans
Standard
Microsoft wireless optical mouse
AT&T U-verse (18mbit/sec)
Other devices:
Compaq CQ-60 laptop
Google Nexus 7 (2012) tablet
Nvidia SHIELD tablet (US/LTE)
Hardkernel ODROID-XU single-board computer (Samsung Exynos 5420)
Thanks for all the replies...
The hdmi goes to my reciever/tv in a different room, the stereo jack goes to my computer speakers. Want to be able to play the same sound in both rooms at the same time...
7 64biti5
hp
7 64bit
i5
does your HDTV have surround sound speakers or do you use the built in factory speakers? or maybe jst 2.1 surround?
Does you HDTV have a 1/8" (3.5mm) phono jack input and/or output? (that is like a headphones plug hole like the ones on the back of computers for the basic speakers or mic)
Biostar TA790XE3
Onboard
