Windows 7: No Audio Output Device is Installed
12 Dec 2011   #161
cruxone
Windows 7 Home Premium 64 bit
Went out to look for the other type of DVD, unsuccessfully. I will give it a shot now.
12 Dec 2011   #162
cruxone
Just tried it. "The File Could Not Be Deleted"
12 Dec 2011   #163
AllOnTheBus
Windows 7 Home Premium 64 Bit OS
Any luck yet?
Mike is this all about making sure a correct backup is performed?
I personally would have gone for the shut down and restart holding
the 0 (zero) key option after the first 20 pages of posts!!! Lol.
If the recovery partition fails to reinstall to factory default then
an OEM disk, the serial number and the manufacturers website could have
got everything back on.
All I'm saying is that this all seems like a hell of a lot of trouble to go to
worrying about something that may or may not even occur. Some people are
the better to be safe than sorry type but I'm the worry about it when it
happens type I guess.
Be done with it guys- restart holding the 0 key!!!
12 Dec 2011   #164
rubyrubyroo
MS Windows 7 Home Premium SP1 64-bit (Family Pack Lic.) Upgrade
just curious did you ever use/have Rosetta stone or make a DVD/CD of it?
12 Dec 2011   #165
rubyrubyroo
working on it allonthebus!
12 Dec 2011   #166
cruxone
I had/used it. I haven't been able to get it off my computer though. I did just delete some other things, though, putting me at 6.55 GB free.
12 Dec 2011   #167
rubyrubyroo
Use/Run fileASSASSIN again, same as before
Quote:
which you should download/install and run. Then there will be a box where you can enter the path/name of the file you want to delete, or click the [...] button to browse for it. Since you have it copied in memory, you should be able to simply click in the open space of the box (NOT the button [...] !!) and simply press ctrl + V to paste the entire path as long as it works,
but his time select the second radio-buton from the bottom "Use delete on Windows reboot function". Now cross your fingers and press [Execute] button.
This should take care of it without windows running.
It will reboot.
Mike
12 Dec 2011   #168
cruxone
Seems to have worked! 10.1 GB free.
12 Dec 2011   #169
rubyrubyroo
that was what I was going to try(after seeing if it would burn off some recovery disc's) but supposedly thats not a good idea, and plus a factory recovery supposedly wont fix the problem. I was planning on trying it anyway once I got Cruxone a fresh real copy of non OEM windows so a reinstall is possible if I and you are wrong, otherwise there would no help from anyone. plus it has so much bloatware on it that it's way to big for that drive. and what do you mean about the venders site? are you tallking about downloading factory images?
12 Dec 2011   #170
rubyrubyroo
great cruxone! You might want to hold off on the DVD step temporararily, but, I'd at least download that image from earlier.... the longer post? let me know if you caant find it (with the .iso file)
I believe this is an issue regarding an update. I had this issue before and did a system restore to back before I had installed a certain program, and the issue went away. Now however, I do not have a restore point that will go far enough back. I started up my computer today and I was hit...
Drivers
no audio output device installed
This is my wife's sony vaio, and she has had this problem with no sound on her laptop, when checking the volume control it says no audio output device installed. In device manager it says that she has Intel display audio. I need major help here please.
No AUDIO OUTPUT DEVICE IS INSTALLED
No AUDIO OUTPUT DEVICE IS INSTALLED, this is the message l got on sound icone since l installed windows 7 l have downloaded it several time the latest one it shows on control panel but not on device manager, l guess this is not really installed but l keep installing it and restat the laptop...
No audio output device installed
I bought a generic computer. It had windows vista installed and it used to display a message that No audio output device is installed . I recently installed windows 7 home premium 32 bit on it but it still says the same thing. I went to properties of it and found following error message.This device...
No audio output device installed...Tried everything, need some help.
All fixed...Hardware issue. Stripped it down and rebuilt it. Booted up and installed the drivers....woohoo I have sound again...lol Hi, I have had this problem now for a couple of months. What I have tried: Reinstall windows 7 Update bios Install the realtek high definition audio...
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
