Windows 7: No Audio Output Device is Installed
19 Dec 2011   #191
cruxone
Windows 7 Home Premium 64 bit
Quote   Quote: Originally Posted by rubyrubyroo View Post
Yeah, that was a bunch of what I was going to tell you to do, pretty much!
  1. Did you get the update from Windows Update or the Toshiba site? (Sorry I'll get to your answer in a minute...) Windows Update
  2. How much room is left on the C : drive now? Less than 2 GB. Would it be cool to transfer my windows.old folder to the bigger drive and then delete it? That would leave me like 30 GB free.
  3. Are you still getting updates (is the win update set to auto install?) I installed the updates, but am not sure if it is set to auto install them. How do I check that?
  4. You must have done a Custom Install, rarther than a Clean Install, or it would have formatted the drive first. So you saved your files (you said earlier) do you mean the copy on the E : drive or on the C : drive in a folder named Windows.old? I followed the tutorial for clean install. Not a big deal right? Windows.old is where all my old stuff is.
  5. I also assume you installed your anti-virus as soon as you were in windows, and updated it to the current virus signature database, etc. I did this immediately.
My answers in red obviously.
19 Dec 2011   #192
cruxone
Also, what other drivers or software will I need or would you suggest I DL from the Toshiba site? NVIDIA? Conexant? Any other video or audio stuff? It seems like my video is really choppy now.
19 Dec 2011   #193
rubyrubyroo
MS Windows 7 Home Premium SP1 64-bit (Family Pack Lic.) Upgrade
I just typed the entire post and hit some messed-up key so I'll be really brief for now:
Windows Update I think thats fine (unless you experience issues in the future - I doubt)
2GB way too Small ---- esp. since win update is likely d/l-ing more each time you power on/off. ----- so yes copy it onto a DVD( or flash drive )if you can, although I doubt you'll need anything off of it really. DON'T copy it onto the other drive, It may be fine, but there's no reason to do that propr to deleting them.
19 Dec 2011   #194
rubyrubyroo
to get to Windows update, press (START) type "update" int he search box and press enter. are there more important/optional updates waiting to be installed?
Click Change Settings... There should be a green sheil in the middle of the screen. that means the updates auto D/L & install.
close out
drivers... wait and see after all have been installed (since I am guessing it's not done yet!) and you can always try that, is other video online similar?
also do you have all the software you need?
Have you checked in device manager to see if there are any errors/warnings/disabled drivers (it's in the control panel under device management (a yellow/red/grey/ or white indicator will show the one's with trouble)
Great with the anti-virus protection !
19 Dec 2011   #195
cruxone
I already transferred the windows.old to the E drive, which for some reason is now called the D drive. I just deleted it and now have 31 GB free on C. Windows update is set to auto. The update is also complete. Youtube seems to work fine after I installed flashplayer. WMP, though, is playing video quite choppy.
Like I said, in device manager, there is no NVIDIA or Conexant any more. Not sure what else is missing though since those are all I had been messing with over the last month. Do I need those?
Do I have all the software I need? Is there anything specific to which you are referring?:
Drivers: Is there somewhere other than device manager to look at these or is that what you were talking about? I am not seeing any of the yellow/gray/white/red indicators anywhere in device manager. Maybe I am looking in the wrong place?
19 Dec 2011   #196
rubyrubyroo
yeah you do need them, but I suspect windows installed them during the install process, or subsequently as it has been probing MS's site for updates.
In Device Manager,
To get to it you can simply press the windows key on the keyboard + R, and enter "devmgmt.msc"
If there are no issues found, then there would be no "colored marks", nor would there be any "sub-items" opened beyond the main headings (great!): So the drivers you didn't see might have been under the header "Sound, Video and Game Controllers" (NVIDIA and Conex't
you said the sound is working? right.
other than the video - and the drive - all is okay seemingly?
19 Dec 2011   #197
cruxone
So I guess there is an issue:
It seems like my graphics are just generally less sharp than before. And again, those drivers I didn't see are not under the heading of sound and video.
I tried to update the driver for that "unknown device" and it didn't find one.
19 Dec 2011   #198
cruxone
My resolution is much worse than it was. When I set it to the highest possible (1280x1024) things become stretched very wide. My work requires higher resolution as I had prior to reinstalling windows. How do I fix this? Would it be a mistake to try and dl NVIDIA?
19 Dec 2011   #199
cruxone
In reference to my resolution being worse, one application I use all the time types in a fairly small font. It was still totally sharp before, but now I can hardly read my typing.
19 Dec 2011   #200
rubyrubyroo
well whats under display drivers?
but also I need to identify the two yellow marked items under the "white marked" heading - Unknown Devices can you look through the lists in each for #'s labeled HID, PIN, VIN and or VEN (hardware, product, vendor) - it should be under the tab(s) Details >>> [Properties]
then in the drop down look for values that have these "id's" in them as you select them....if that makes sense
I believe this is an issue regarding an update. I had this issue before and did a system restore to back before I had installed a certain program, and the issue went away. Now however, I do not have a restore point that will go far enough back. I started up my computer today and I was hit...
Drivers
no audio output device installed
This is my wife's sony vaio, and she has had this problem with no sound on her laptop, when checking the volume control it says no audio output device installed. In device manager it says that she has Intel display audio. I need major help here please.
No AUDIO OUTPUT DEVICE IS INSTALLED
No AUDIO OUTPUT DEVICE IS INSTALLED, this is the message l got on sound icone since l installed windows 7 l have downloaded it several time the latest one it shows on control panel but not on device manager, l guess this is not really installed but l keep installing it and restat the laptop...
No audio output device installed
I bought a generic computer. It had windows vista installed and it used to display a message that No audio output device is installed . I recently installed windows 7 home premium 32 bit on it but it still says the same thing. I went to properties of it and found following error message.This device...
No audio output device installed...Tried everything, need some help.
All fixed...Hardware issue. Stripped it down and rebuilt it. Booted up and installed the drivers....woohoo I have sound again...lol Hi, I have had this problem now for a couple of months. What I have tried: Reinstall windows 7 Update bios Install the realtek high definition audio...
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
