Windows 7: No Audio Output Device is Installed
19 Dec 2011   #221
cruxone
Windows 7 Home Premium 64 bit
There is no heading "hard drives"
Maybe you meant "disk drives"? You can see what is there now.
19 Dec 2011   #222
rubyrubyroo
MS Windows 7 Home Premium SP1 64-bit (Family Pack Lic.) Upgrade
and hardware id is the only drop-down menu item (that has anything in it anyway? (in the last post)
yeah i meant disk drives, and that should be good......
19 Dec 2011   #223
rubyrubyroo
I have to do something, I'll be back in around 1/2 hour (you can try the video driver - just remember F8 during boot to get the "Advanced Options menu" and start windows in safe mode w/ networking or VGA standard resolution mode, and you should be able to get back in and "roll" back the driver using the button in the drivers tabs)
If you have to go, then, well finish later, or whenever, otherwise if your here, I'll stop back in.
Mike
19 Dec 2011   #224
cruxone
Yeaaaaaah BUDDY!!!! I am all set up!
19 Dec 2011   #225
rubyrubyroo
? HD video is working correctly now ?
did you instal the one driver only to fix it?
19 Dec 2011   #226
cruxone
Ya, jsut the one. Should I install others?
20 Dec 2011   #227
rubyrubyroo
I must have missed you the other day, when you we online. Yes I would install some of the other drivers from the site, again not a bunch at a time, since if a problem occurs, you'll know which one needs to be avoided. I would start with your chipset driver FIRST.
Also I never heard if the sound was working perfectly again w/o any issues (and the software shows both devices - and the headphones when plugged in at least)
And need to straighten away the second drive so you don't fill up quickly again! (did you remove the hyberfil.sys file?)
lemme know!
Mike
(BTW: CONGRATULATIONS on getting it working again!)
23 Dec 2011   #228
rubyrubyroo
Hello Nick,
I am guessing your not going to return to fix the remaining items, or you had a problem leading to the loss of a functional computer. In either case, you should be aware that from my understanding, you tried to install windows on your second drive and when it didn't work properly you installed it on your primary drive. I don't know how far you got to the first install. I'm not quite Martian of the legalities of this type of situation, but It could be considered as a duplicate installation and be illegal. I recommend you check into this with Microsoft to be sure. You will need to fix that second drive, or you could experience problems at startup, rendering windows unaccessible, temporarily at least. Someone should help you fix the MBR to the correct boot setup for your one and only OS on the primary drive (the smaller SSD drive) (C . Then the second drive can be formatted and used as you wish.
I wish you the best!
Mike
30 Dec 2011   #229
eiger3970
No Audio Output Device Installed. Red cross on Volume icon in task bar.
1. MOBO sound card won't work.
2. Installed sound card won't work.
3. I posted this previously and installing the sound card fixed the issue.
Unfortunately, I reinstalled Windows 7 and now no sound works on the MOBO or sound card?
Update Driver Software cannot find driver software for my device.
30 Dec 2011   #230
rubyrubyroo
Hi Eiger3970,
where did you get the driver that worked for you before?
Mike
should start a new post, you'll be more likely to get help since noone want to read a 5+ page post!
I believe this is an issue regarding an update. I had this issue before and did a system restore to back before I had installed a certain program, and the issue went away. Now however, I do not have a restore point that will go far enough back. I started up my computer today and I was hit...
Drivers
no audio output device installed
This is my wife's sony vaio, and she has had this problem with no sound on her laptop, when checking the volume control it says no audio output device installed. In device manager it says that she has Intel display audio. I need major help here please.
No AUDIO OUTPUT DEVICE IS INSTALLED
No AUDIO OUTPUT DEVICE IS INSTALLED, this is the message l got on sound icone since l installed windows 7 l have downloaded it several time the latest one it shows on control panel but not on device manager, l guess this is not really installed but l keep installing it and restat the laptop...
No audio output device installed
I bought a generic computer. It had windows vista installed and it used to display a message that No audio output device is installed . I recently installed windows 7 home premium 32 bit on it but it still says the same thing. I went to properties of it and found following error message.This device...
No audio output device installed...Tried everything, need some help.
All fixed...Hardware issue. Stripped it down and rebuilt it. Booted up and installed the drivers....woohoo I have sound again...lol Hi, I have had this problem now for a couple of months. What I have tried: Reinstall windows 7 Update bios Install the realtek high definition audio...
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
