Windows 7: No Audio Output Device is Installed
02 Dec 2011   #71
rubyrubyroo
MS Windows 7 Home Premium SP1 64-bit (Family Pack Lic.) Upgrade
This is what I had remembered incorrectly:
Quote:
-I have tried going into "Services" and restarting my "windows audio" and "windows audio endpoint builder" services
(Post 1)
02 Dec 2011   #72
AllOnTheBus
Windows 7 Home Premium 64 Bit OS
No dramas- just saying is all
By the way- good idea bout the updates- I'd also
recommend going into Control Panel->WindowsUpdate->
Change Settings and ensuring that the recommended updates
checkbox is ticked ("Give me recommended updates the same way I recieve
important updates") as this is where the driver updates load into. If the box
is already checked and Windows is set to auto download AND install updates
then a worthwhile check for sure.
02 Dec 2011   #73
rubyrubyroo
yes, good suggestion! I guess OP is rebooting... I'll be watching for a post!
02 Dec 2011   #74
AllOnTheBus
Apologies for double posting but maybe I wasn't understood before
about the services checking thing- then again maybe it's exactly the
same thing and I don't know it.
If it isn't the same thing (and from the screenshots before I didn't recognise those windows as that is
not the way I entered into local services) then please try this because God forbid
we should miss anything at this stage of the game:
Click the Windows orb (start button)
Type in Admin
Select Administrative Tools
Select component services
Select Services (Local)
Find the Power service in this list
Check the setting - it should be set to autostart
Is it the same thing - i profess not to know - however it looks nothing like
the screenshots posted before of the services you were checking.
Give it a go- it can't hurt right!
What I am saying is that if the OP entered services (local) where I did as recommended through this http://answers.microsoft.com/en-us/w...6-4fc866efbb22
informational page then the screenshot should have looked something like this:
Attachment 186391
02 Dec 2011   #75
cruxone
Windows 7 Home Premium 64 bit
Quote   Quote: Originally Posted by AllOnTheBus View Post
Type in Admin
What I am saying is that if the OP entered services (local) where I did as recommended through this No sound in Windows 7 Pro 64 bit - Audio Service not started - Audio - Microsoft Answers
Attachment 186391
Ya. Its the same thing. Sorry guys, I had to run out for a bite. Going to look through the update stuff and post some screenshots.
02 Dec 2011   #76
rubyrubyroo
Yeah, it is the same thing. Component services has 3 components to its snap in. one of which is Services "(Local)" (Just as computer management has Services, their just more convenient for use in the grouped manner that component services is set up, depending on the situation. (when you merely goto Services, the title bar is labeled w/o the "(Local)" part because it is derived from the name of the file "services.msc" the title of the snap-in is the same if you look at the top of the window below the menu and toolbar that is the title of the snap-in component and it is Services (Local). If thats your question, these are the same thing, aside from the grouping. Unless you meant something else? Its hard to read my screen at this hour!
Mike
02 Dec 2011   #77
rubyrubyroo
great me too soon. im starving!
We both await!
Mike
02 Dec 2011   #78
AllOnTheBus
7 hours straight here
Maybe that's why I echoed Mike in regard to checking the recommended updates.
Anyways that's great news bout it being the same thing at least that
has been eliminated as an option. I must try to remeber that.
Good luck
02 Dec 2011   #79
cruxone
Ok. Definitely failed updates, definitely the day it quit working.
I tried a couple times just now, as you can see, and it failed. At first it failed because there wasn't enough space on my hard drive. I have 2 drives and, for some reason, the one that runs things is nearly full. I deleted some stuff and there should be enough space, but it still didnt work. It said there was an unknown error, which I posted a shot of.
02 Dec 2011   #80
rubyrubyroo
Thats definitely a problem, It must have started the download and run out space, leaving corrupt files partially written. , now its trying to finish the update where it left off , but that's not going happen like that. now we know the source, let me make sure I know the CORRECT manner to remedy it, and not forget something.
I'll post back shortly...
Mike
I believe this is an issue regarding an update. I had this issue before and did a system restore to back before I had installed a certain program, and the issue went away. Now however, I do not have a restore point that will go far enough back. I started up my computer today and I was hit...
Drivers
no audio output device installed
This is my wife's sony vaio, and she has had this problem with no sound on her laptop, when checking the volume control it says no audio output device installed. In device manager it says that she has Intel display audio. I need major help here please.
No AUDIO OUTPUT DEVICE IS INSTALLED
No AUDIO OUTPUT DEVICE IS INSTALLED, this is the message l got on sound icone since l installed windows 7 l have downloaded it several time the latest one it shows on control panel but not on device manager, l guess this is not really installed but l keep installing it and restat the laptop...
No audio output device installed
I bought a generic computer. It had windows vista installed and it used to display a message that No audio output device is installed . I recently installed windows 7 home premium 32 bit on it but it still says the same thing. I went to properties of it and found following error message.This device...
No audio output device installed...Tried everything, need some help.
All fixed...Hardware issue. Stripped it down and rebuilt it. Booted up and installed the drivers....woohoo I have sound again...lol Hi, I have had this problem now for a couple of months. What I have tried: Reinstall windows 7 Update bios Install the realtek high definition audio...
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
