How do i fix my multimedia audio controller & pci input device driver?
  1. Posts : 3
    Windows 7 Ultimate 32bit
    My mobo is foxconn G31MV-K, Socket 775
    Processor : Intel(R) Pentium(R) Dual CPU E2180 @2.00GHz @2.00Ghz
    RAM : 1.00 GB
    OS : Windows 7 Ultimate 32-bit
    Audio: 5.1 HD audio by Realtek® ALC662-GR
    The main problem is the multimedia audio controller & pci input device in the device manager always have a sign of (!) and when I check the properties, it's said code 28(If i'm not mistaken). I have installed the driver from the manufacturer, but still the sound won't come out.Could anyone help me please?I'm not too good in computer stuffs..Thanks:)
    Install the motherboard Chipset Drivers and then the sound drivers. That usually takes care of problems such as this.
  3. Posts : 3
    Ok, I'll try it. Thanks
  4. Posts : 3
    So sad, I already install the system and chipset driver also on-board audio driver. But still, the sound won't come out, any other suggestion?
  5. Posts : 8,135
    There is some hardware problem or the right drivers are not being installed. The chipset drivers define (identify) all the hardware devices on the motherboard. Since you apparently have at least two hardware devices with problems it goes back to either a motherboard hardware problem or chipset drivers. On a Foxconn motherboard (which are used in many Dell's and Foxconn makes many Intel motherboards) the chipset drivers MUST be installed BEFORE installing the sound drivers and some other devices or the drivers will not install and the Code 28 says the drivers are not installed.
    Reset the BIOS and see if that helps. It's a long shot but worth a try.
