No Audio Output Device is Installed
Page 9 of 23 FirstFirst ... 789101119 ... LastLast
  1. Posts : 1,777
    MS Windows 7 Home Premium SP1 64-bit (Family Pack Lic.) Upgrade
       #81
    First Lets see exactly what your system is reporting, as my last post was an assumption, and it could be another error just as easily that occured unrelated to the HDD space.
    * If installed it should indeed be showing via Start > right click Computer > Properties >Viewing Basic Information > Windows Edition.
    * Have you checked in Event Viewer?
    Type eventvwr in search.
    Go to the Windows Logs > Application { then System} > in the left hand column.
    Note any error or warning that relates to when you installed SP1.
    Please note the event ID, and the source codes and tell us what they are.
    then click (Start) and enter the text msinfo32 and press enter.
    then type the version number on the second line, fully.
    Mike
  2. Posts : 109
    Windows 7 Home Premium 64 bit
       #82
    Sorry, Mike, but I am unclear as to exactly what you want me to do. Here is what I found:
    What else should I do?
  3. Posts : 109
       #83
    Version number =
    6.1.7600 Build 7600
  4. Posts : 1,777
       #84
    and that version # is from msinfo32.exe or the first instruction in the quote (properties)? or do the match exactly? Ill look at your screen shots (above) now.
  5. Posts : 109
       #85
    Second line of msinfo32
  6. Posts : 1,777
       #86
    The screenshots are great, if I need more I'll ask.
    I'm reading through several solutions, at MS and here at SF but either way you should check your system for errors that may have happened during that faulty SP1 installation. Heres the tutorial: SFC /SCANNOW Command - System File Checker
    Mike
  7. Posts : 109
       #87
  8. Posts : 109
       #88
    I am signing off for a couple hours. Seems like we may be on the verge though, so I am optimistic. Thanks a lot guys.
  9. Posts : 1,777
       #89
    Okay, lets see what couldn't be fixed (it was step 3 in the tutorial - but its simple enough just read it here)
    Open an elevated command prompt just like you did before (or use the same window if it is still opened:
    copy and paste the command:
    findstr /c:"[SR]" %windir%\Logs\CBS\CBS.log >%userprofile%\Desktop\sfcdetails.txt
    then press enter and it should copy the file "sfcdetails.txt" to your desktop.
    locate it and double click it to open it with a text viewer like notepad.
    report the results.
    (BTW do you have antivirus software running - You may have told me already, but rather than look back.)
  10. Posts : 109
       #90
    I run Avira antivirus. The results of that command are pretty long:
