No recordable sound
  1. Posts : 36
    SEVEN ultimate 64bits
    No recordable sound
    My motherboard M5A78L has an on-board Realtek HD Audio sound card. Works well, unless the fact that the Sound Recorder that comes at Accessories does not work because, it said, "there is no recording device connected."
    However, I have LinuxMint11 as guest in VMware. At this, the sound recorder records any sound that comes from the PC's speakers! good one!
    In win7 already changed the sound driver, no results
    To me this is a "mystery", since usually who does not recognize sound device sometimes, is Linux.
    What to do?
  2. Posts : 72,052
    Hello Jaca,
    You might check to see if this may be the issue to make sure that you have "What U Hear" enabled.
    "What U Hear" Recording - Enable
  3. Posts : 8,135
    Just to clarify since it has the RealTek integrated audio, it will either be "System Mixer" or "Stereo Mix". The "What You Hear" is the SoundBlaster name for the System Mixer function.
  4. Posts : 36
    Worked!!! (costs so few to be happy, is'nt?)
  5. Posts : 72,052
    That's great news Jaca. I'm happy that we were able to help. :)
