no audio when connecting hdmi to syncmaster 2333hd monitor
arjang
8:02 PM
hi all
my problem is that when i connect my PC to syncmaster 2333hd monitor via HDMI, there is no audio output from the monitor!!! i have already done as 2333hd spec requires, disabling audio from HDMI and connecting a mini audio cable. i downgraded my graphic card driver but still no luck!! any help wud be very much appreciated
product spec:
2333hd monitor
GeForce 9600GT
windows 7
windows 7
Try right clicking the speaker icon in the system tray then go with play back devices. Make it default in there.
Windows 7 Pro x64 -- PCLinuxOS KDE4 FullMonty...i7-875k @ Turbo - 7,6,5,5 - 3.6ghzCorsair CMD8GX3M4A1600C8 8gbAsus EAH5850 DirectCU/2DIS/1GD5
Windows 7 Pro x64 -- PCLinuxOS KDE4 FullMonty 2011
Asus P7P55D-E Deluxe
On Board
Samsung SyncMaster T220 - Panasonic VT30a 50"
1680x1050 -
Corsair Force 3 SSD 120GB x 2 ::
WD VelociRaptor 150GB WD1500HLFS x 2
Corsair HX-850 Power Supply
Coolmaster HAF 932
Corsair H50
Logitech Wireless MK700
Logitech Wireless MX620
Good enough for now
Voip. Insanely cheap phone calls.
the speaker is set as default. there is audio when i plug my headphone but no audio from my monitor speaker
windows 7
windows 7
anyone can help plz ??????
windows 7
windows 7
You have the speaker set to On or Off in the monitor's settings? Looking at the manual it would appear that the correct setting would be Off,
Also unless your 9600 has a SPDIF header on it like the cards shown here,
Guide: 8800GT/9800GT/9800GTX Sound over HDMI (Now including Creative cards)
and connected to the SPDIF header on either the motherboard or sound card, you won't get sound over HDMI from it despite it having a HDMI port on the card.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Like stormy13 suggested make sure you are using the audio cable to connect the video card to your sound cards spdif output. Also if you do have it installed and its still not working try flipping the connector on the sound card side of the cable -it should only plug in one way on the video card.
windows 8.1 Pro x64intel [email protected]2x8gb ripjaws x @2133asus r9-290@1100/1300
Elsa
windows 8.1 Pro x64
msi mpower max ac
creative sbz
dell u3011
840 evo 250 & 8.5tb
evga supernova p2-1000
corsair air 540
corsair h100
logitech g710+
logitech g502
avg
firefox
Spidf
To receive audio on monitor using HDMi u have to use SPIDF
I have a Gainward 9600 Gt and all i did is conect a cable from it to my motherboard on the SPIDF conection. And works like a charm.
The audio cable the Syncmaster has is only used with VGa cable i think.
You don't want the "speaker" set as default output. You want the device your connected to as the default output. In this case, your Monitor. It should be listed in the Playback devices. All devices capable of audio output should be listed. If you want the audio to be played on the monitor speakers, you must select the monitor as the default audio playback device.
The image below shows a sample of Playback devices. It currently indicates Speakers since I have external 5.1 speakers attached. If I want the audio to be played through the TV/Monitor, it needs to be selected as the default playback device.
Windows 7 Pro-x64i7-2600 3.4GHz - 3.8GHz Turbo8Gb - 2x4GB, Muskin 991770 PC3-1333Integrated Intel HD 2000
Built 2/11/2011
Windows 7 Pro-x64
Intel DH67BL-B3
Integrated Intel 10.1 HD, RealTek ALC892
Asus LCD VH222H, Haier HL24XSL2a
1920x1080, 1920x1080
Crucial SSD C300-128Gb,
Western Digital WD5002AALX - 500Gb,
Western Digital WD7501AALS - 750Gb
Seasonic 650W 80+ Gold Modular
Rosewill Defender
Stock CPU, Four 120mm case fans, PCH fan added
Logitech EX100 Y-RBH94 Wireless
Logitech EX100 M-RCE95 Wireless
3.0/1.5 Mbs
Microsoft Internet Explorer 11
Antec Veris Premier-Multimedia IR Station,
Cyber Accoustics-3602 Speakers,
AFT XM-5U Card Reader,
Hauppauge TV-HVR-2250,
Sony LX300 USB Turntable
