Sound/Mixer icon has red cross. No Audio Output Device is installed.
eiger3970
1:11 AM
Windows 7 32-bit won't play sound.
Device Manager\Sound, video and game controllers\High Definition Audio Device ok.
Double click and window says:
High Definition Audio Device Properties\General: Device status says This device is working properly.
Speakers are plugged in and make a crackle when plugging in to correct holes.
Mystery?
Windows 7Intel Pentium 4 @ 2400 MHz1024 MB (1 x 1024 DDR-SDRAM)NVIDIA GeForce 7600 GS (Microsoft Corporation...
Self built pc.
Unspecified P4M266A-8237
NVIDIA GeForce 7600 GS (Microsoft Corporation - WDDM)
Onboard VT8233/A AC'97 Enhanced Audio Controller
Samsung SyncMaster - 17 inches
1280x1024
SAMSUNG (400 GB)
WDC (80 GB)
VIAP4X SLIC-MPC 450 Watt
Unknown
Processor fan 3750 rpm
Belkin ergonomic
Logitech laser
Cable up to 8Mbps
PC runs at about 59.9 centigrade.
If it's shown as "working properly" in the Device Manager, the speaker icon you have can also be because the sound is muted.
You show "High Definition Audio Device" rather than the actual sound device which suggests you have the generic Windows/Microsoft installed sound driver rather than the actual sound driver from the motherboard vendor. In many cases the generic Windows driver does not work or work correctly.
You can try and uninstall/reinstall by RIGHT clicking on the entry for the sound and then LEFT click "Uninstall" (DO NOT check the box to uninstall the drivers) then restart the PC and when Windows starts it will detect and reinstall the sound. This fixes a lot of flakey problems.
If the uninstall/reinstall does not fix it, the next step is to get the correct sound drivers and install them.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
