Earforce DX11 turtle beach no sound output./3.5mm jax issues
berrybuzz
12:12 AM
va
Hello prethankyou for reading and responding to this post and for the helpful incite (or not so helpfull least ya tried) ok so
comp specs
windows 7 ultimate 64 bit
gtx 580
i7 2.6k ghz
i cant remeber motherboard atm my apologies but its newer.
using realtek audio drivers.
I am using hdmi as my video out and it produces sound through my tv. when i plug in a standard headphone (which works with my ipod) into the front 3.5mm jack no sound comes out. I disable front jack detection and still nada. However when i disable the front jack it suddenly says headphones plugged in however still no sound. I have tried with the exclusivity mode on and off for this test. I tried the back 3.5mm jack as well and nada.
So then i try with m earforce dx11 turtle beach pluging in the spdif still nada. i try plugging it in with just the usb pink and green 3.5mm in btoh the front and back panels an still nada. so yea any ideas? i have no other monitor but my tv so i can't test if the hdmi is the problem.
also note- when plugged in the front pannel i can hear my self talking and its coming through the headphones but no computer sound will.
windows 7 ultimate 64biti7 2600k intel16gnvidia gtx 580
bought from nexgen LLC on ebay
i7 2600k intel
Biostar TP67B+ Motherboard
16g
nvidia gtx 580
32inch dynex 1080p tv + 46inch dynex 1080p lcd
1920x 1080
2tb black cavalier WD
fios
Hello BerryBuzz,:D Welcome to Seven Forums!
Have you tried adjusting the individual volume controls for different types/inputs of sound (since your headphones MUST be working if you can hear yourself (I'm assuming you mean through when you speak through the microphone? any clarification may help. Because if you happen to mean your recorded voice, then there shouldn't be any difference between that and a "normal sound file"!?! Also may want to check the Device manager to be sure there's no obvious driver issues.
Is this something you just noticed happening even though you've been using headphones for a while now, or is this a problem with it's origin not really something you can point toward, because you've never really used headphones?
Because If you have an idea of when it started, there's error reports, the windows update install history and system restore points that may prove to be useful in your problem.
Any helpful clarification?
Thanks,
Mike:)
MS Windows 7 Home Premium SP1 64-bit (Family ...AMD Phenom II X6: Black Ed 1090T - AM3 / 3.2G...2 dual ch sets OCZ DDR3 PC3-10666 Platinum 13...Onboard
Custom self build - Desktop
MS Windows 7 Home Premium SP1 64-bit (Family Pack Lic.) Upgrade
AMD Phenom II X6: Black Ed 1090T - AM3 / 3.2GHz / 8MB
Biostar TA790XE3
2 dual ch sets OCZ DDR3 PC3-10666 Platinum 1333MHz 8GB total
Onboard
Onboard 5.1 channel HD
SyncMaster "Legal-sized" LCD (rotatable)
unknown (8.5"x15")? pixels are not known
HDD1: WD RE3 Enterprize [p/n: WD500ABYS-NDW]
________SATA-II (3Gb/s) 500GB/7200rpm/16MB
HDD2: Deskstar 7K1000.C [p/n: HDS721010CLA332]
________SATA-II (3Gb/s) 1TB/7200rpm/32MB
Antec 900W mATX 20+4 w/6-8SATA;2MLX;4x6(+2)PCIe[p/n HCG-900]
Mid 10-bay tower - free space design interior & well vented
CPU HS cooler, 14.5" Case-sysfan1, dual sysfan2, exhaust
Blue Star Ergonomic - ps/2
LED coorded w/v. roller wheel - ps/2
GbLAN 10/100/1000 & WLAN - on T1 (Peer Network)
Harmon-Karden speakers (L,R @ sub)
APC (Lead/Acid Batt backup UPC+Surge protector+etc)
Sony DVD SATA(300) - RW DVD/CD SATA-II(300)
No both the 3.5mm jacks have never worked when i just bought it. All the drivers were on a cd from the vendor and were updated.
and yes i can hear myself speak in the headphones but its not sending the sound from the tv to the headphones. (turtles use spdif plug in the back also the hardware is correctly setup already made sure of that from the manual)
i7 2600k intel
16g
nvidia gtx 580
1920x 1080
fios
