Microphone and Speakers Problems (IDT Audio)
Chris13
9:25 PM
Hello everyone.
This post is related to my other posts in this thread:
http://www.sevenforums.com/crashes-debugging/195347-several-different-bsod-while-watching-videos.html
Laptop: Dell Inspiron N5110
Here is the problem:
-Main problem:
After updating my laptop's drivers (every update DriverMax has found) I had many problems, but I fixed them somehow (with more "updates" if I remember correctly). That left me with one serious problem for me that I am not able to fix..
My laptop's microphone is ruined! (And I don't know which specific driver caused this problem)
When I try to record or speak to someone through Skype, it makes very loud and strange noises!
The other side can only hear those noises (Even I am able to hear them) and they are really a pain..
I have tried changing some settings on Skype...nothing.
I have changed several settings on IDT Audio Control Panel...nothing.
I have connected a headset and the problem is the same!
I tried to update the IDT driver (29/09/2011 - Version: 6.10.0.6341, A03) from dell website...nothing...uh wait!...something changed!
Now my headset's microphone is not working at all(!) and the problem keeps growing..
-Another problem:
I have another problem related to the laptop's speakers this time.
I am not sure if it is also a driver's problem.
When I am listening to music and increase the audio at over 50%, it sounds weird, like old speakers do, a lot of noise.
I did a search and many people with the same laptop model have the same problem and some of them are saying that it is a hardware problem.
I can listen to music using a headset with no problem at all.
Does this mean it's a hardware problem or can it be a driver problem again?
Thank you in advance.
Windows 7 Home Premium 64bitIntel(R) Core(TM) i7-2630QM CPU @ 2.00GHz (8 ...4096MB RAMIntel(R) HD Graphics Family ~ NVIDIA GeForce ...
Dell Inspiron N5110
Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz (8 CPUs), ~2.0GHz
4096MB RAM
Intel(R) HD Graphics Family ~ NVIDIA GeForce GT 525M
If you go to Start and open device manager, (type device manager and open it) do you see any little yellow triangles anywhere? If you don't, open the Sound, video and game controllers category and see if there are any in there. If there are, tell me what they say, or better yet, post a screenshot of them.
Usually, it's not a good idea to use any software like that to find drivers for you. They often mess up and cause bigger problems, like you're having. In fact, on windows 7, once you manually find your network drivers so your computer can connect to the internet, Windows Update usually does an excellent job of automatically finding and installing all the drivers you need. They really improved it since Vista had so many driver problems.
MS Windows 7 Ultimate 64-bit SP1Intel Mobile Core 2 Duo T6400 @ 2.00GHz, Penr...4.00 GB Dual-Channel DDR2 @ 399MHz (6-6-6-18)Mobile Intel(R) 4 Series Express Chipset Fami...
Dell Inspiron 1545
Intel Mobile Core 2 Duo T6400 @ 2.00GHz, Penryn 45nm
Dell Inc. 0G848F (Microprocessor)
Mobile Intel(R) 4 Series Express Chipset Family (Integrated)
Generic PnP Monitor (DPMS) (1366x768@60Hz)
1366x768 (16:9)
2TB External, with ~1TB partition booting OS
Laptop vent
Touchpad, and Logitech wireless USB mouse.
~150 kb/s
I'm running Windows COMPLETELY off a 2TB portable hard drive (since my 300GB internal drive just isn't big enough). It works exactly the same as it would normally, only it has to be constantly connected to my USB port. Obviously. I'll show you how to do it, if you ask! It's pretty cool.
Specs via Speccy
No yellow triangles at all.
Thanks for the advice..I shouldn't be messing with the drivers too much, but I did.
I wanted to update them to improve the sound quality.
Dell Inspiron N5110
4096MB RAM
Ok, the next easiest thing would be to use a restore point to go back to before you started all this. In Start, type system restore and click on it. When the window comes up (might take a minute or so, depending on how efficient your computer is) click on "Chose a different restore point" and hit next. Check the box that says "Show more restore points." Then look to see if there's a date from before you started all this with your drivers. If there is, just select it, hit next, and follow the instructions (it'll probably just say not to touch anything until it's done.) Note that this will basically put your computer back to the way it was on that date, but that nothing in any of your personal folders will be affected. Only system things, like installed programs and drivers.
If you don't have a restore point from before all this, let me know and we'll try something else.
Dell Inspiron 1545
1366x768 (16:9)
Laptop vent
~150 kb/s
Specs via Speccy
Ok this is harder than it looks.
I have deleted the recent system restores.
If I knew about all of these problems the day I updated the drivers, I would have done a system restore of course.
Also I have to mention that I won't do any re-installation of Windows 7, because it reminds me the horrible days of Windows Vista :rolleyes:
I am wondering if there is a way that I can get back to the original dell drivers, affecting ONLY the drivers?
Dell Inspiron N5110
4096MB RAM
Ok. I've never tried it before, but if you go into device manager, right-click and choose properties for your sound driver, and go to the Drivers tab, there should be a button that says "Roll back driver." Try clicking that and see what happens. I've never had to do it before, so I don't know exactly what it's going to do. But it sounds like that's what you're looking for.
Dell Inspiron 1545
1366x768 (16:9)
Laptop vent
~150 kb/s
Specs via Speccy
By doing that something should change, because it goes back to the previous version.
However, everything remains the same...
Should I try to uninstall the driver (doing that, will go back to the windows driver), or will it cause more trouble?
Dell Inspiron N5110
4096MB RAM
Hello and Welcome Chris13,
I assume you have no backups of you system either, correct?
The Manufacturer's website will often have older versions archived in the same "download/drivers" area where you found the newest driver. You might want to try an older version, sometimes that can resolve the problem. (this can always be rolled back, as long as you don't install more than one driver per rollback, as you did initially.)
Your other alternative is, as you mentioned, to uninstall the driver, and allow Windows Updater t reinstall it. You'll want to reboot after uninstalling the driver. (This method also depends on your Windows Updater settings, you may need to physically go into Windows Update and see if there are any Recommended or Optional drivers that relate to your sound card available and complete the update process by checking it and starting the update.)
Be sure to let us know either way please!
Mike :)
MS Windows 7 Home Premium SP1 64-bit (Family ...AMD Phenom II X6: Black Ed 1090T - AM3 / 3.2G...2 dual ch sets OCZ DDR3 PC3-10666 Platinum 13...Onboard
Custom self build - Desktop
MS Windows 7 Home Premium SP1 64-bit (Family Pack Lic.) Upgrade
AMD Phenom II X6: Black Ed 1090T - AM3 / 3.2GHz / 8MB
Biostar TA790XE3
2 dual ch sets OCZ DDR3 PC3-10666 Platinum 1333MHz 8GB total
Onboard
Onboard 5.1 channel HD
SyncMaster "Legal-sized" LCD (rotatable)
unknown (8.5"x15")? pixels are not known
HDD1: WD RE3 Enterprize [p/n: WD500ABYS-NDW]
________SATA-II (3Gb/s) 500GB/7200rpm/16MB
HDD2: Deskstar 7K1000.C [p/n: HDS721010CLA332]
________SATA-II (3Gb/s) 1TB/7200rpm/32MB
Antec 900W mATX 20+4 w/6-8SATA;2MLX;4x6(+2)PCIe[p/n HCG-900]
Mid 10-bay tower - free space design interior & well vented
CPU HS cooler, 14.5" Case-sysfan1, dual sysfan2, exhaust
Blue Star Ergonomic - ps/2
LED coorded w/v. roller wheel - ps/2
GbLAN 10/100/1000 & WLAN - on T1 (Peer Network)
Harmon-Karden speakers (L,R @ sub)
APC (Lead/Acid Batt backup UPC+Surge protector+etc)
Sony DVD SATA(300) - RW DVD/CD SATA-II(300)
I don't think I have any backups.
I have installed an older version that one friend uses without any problems (6.10.0.6324), but the problems remain for me.
I also tried to uninstall the driver and have windows to install it.
It went back to the latest driver I used (6.10.0.6341).
The problems remain and now I can't even access the IDT Audio Control Panel getting the message: "Cannot find .startup file!.".
I noticed my friend (same laptop model) has a driver called "Intel(R) Display Audio", which I don't have.
What's wrong with the drivers nowadays? :sick:
Dell Inspiron N5110
4096MB RAM
What do you have installed currently for anti-virus/anti-malware protection? Have you ever uninstalled any anti-virus/anti-malware software from this system in the past?
With the additional issues in your previous BSOD thread, I think you might have a larger problem going on. I would recommend doing the folioing:
Check Windows Update installation history and see if you have any failed installations listed in the list-box (you'll have to scroll down - the last column should say "successful" or "failure")
Run the system File Checker to determine if windows has any corrupt files: SFC /SCANNOW Command - System File Checker
Check your system for malware using the free version of MBAM and preforming a FULL scan: Malwarebytes
Check your hard drive for errors: How to Run Disk Check in Windows 7
Also try to look in Event Viewer for any Critical/Errors. If you need more help with this one Let me know when you complete the previous items and I'll give you more details.
I have a feeling this will give us an idea of what is going on. You may need to do a repair install or possibly a clean install, but it is unclear until this information is gathered. I know it's a lot, but it's important!
Thanks,
Mike :)
Biostar TA790XE3
Onboard
I have ZoneAlarm Extreme Security.
I had the McAfee Security Center that came with my dell laptop and expired in one month and I uninstalled it.
Windows Update history: "Security Update for Microsoft Visual C++ 2008 Service Pack 1 Redistributable Package (KB2538243)" 3 times.
"Security Update for Internet Explorer 8 for Windows 7 for x64-based Systems (KB2544521)".
System File Checker: "Windows Resource Protection did not find any integrity violations."
Malwarebytes: 2 Objects infected / 2 keygens actually - Ignored them...
Disk Check: No errors.
Event Viewer: I am not familiar with it but as I can see there are too many errors.
Dell Inspiron N5110
4096MB RAM
Okay, thank you Chris! :)
I am actually kind of surprised he system file scanner went so well, but that's a good thing. Could you please post the log file from the MBAM scan - use the paper-clip icon box with the down arrow to upload the text file using one of the browse buttons on top. (First you'll have to open MBAM and click on the logs tab, and select the scan you just ran and press the [open] button then save the file to your desktop so you can easily find it from the browse window I just mentioned.)
Also, when you were done with Mcafee's trial period did you uninstall it from the control panel like a normal application is uninstalled? With most all anti-virus/anti-malware apps/suites you'll need to use the vender's uninstall tool to completely and effectively remove the software from your HDD or it can cause a wide range of problems at some point in the future. It often places locks on certain files and alters permissions as a safeguard against viruses but, when not fully uninstalled properly, it's a potential candidate for some of your issues at least.
The tool for McAfee's removal is run after a normal uninstall, so you completed that portion, now the tool (MCPR.exe) must be downloaded, there is a link on the instruction page at McAfee's site to download it, read the instructions and run that tool. Here is the web-site: McAfee Removal Tool Instructions
Are you using Internet Explorer 8.0 or 9.0?
Are the Key-Gens something you used, IOW do you know how they got there? If not that's not a good thing, but also if you did use them - anything like that is prone to a high rate of viruses/Trojans. Which also leads me to ask if you use any torrent software? (only because AGAIN that heavily shifts the scales toward an infection.)
Have you checked your anti-virus app's logs/records to be sure it didn't find anything, and that it is fully updated on a very regular basis? (daily is best)
Thanks,
Mike
Biostar TA790XE3
Onboard
MBAM log file:
View attachment mbam-log-2011-12-24 (18-23-25).txt
I have uninstalled McAfee completely using 'Windows 7 Manager' Smart Uninstaller method.
I am sure nothing is left behind.
I have also used the McAfee's removal tool to make sure.
Now my McAfee site Advisor is gone as well..:huh:
I am "using" Internet Explorer 9.0.
I know those 2 keygen files and I trust them. They are not harmful or anything.
My anti-virus is updated daily and it has not detected anything...
Why do you insist that the problem HAS to be a virus or something harmful?
All of the problems occurred the day that I updated the drivers.
I found out some of them that day and some others later.
Someone has told me that I have problems with the drivers because I haven't installed them in the correct order.
Can something like that be true?
I thought that this was used in the stone age or something.
My laptop's microphone still makes loud stupid noises and my headset's microphone is still not working..
When I did a search many people (same laptop model) are facing problems with not only the speakers but the microphone as well, saying that they can hear the fan's noise instead of their voice.
*PS: I forgot to mention that after the IDT Audio driver update, I can see "Rec. Playback" (Currently Unavailable) in the recording devices.
Dell Inspiron N5110
4096MB RAM
Thank you for posting the requested info!
As to your question(s):
Why did I check for malware? Because it could easily be the cause and I wanted to try to rule it out. You obviously didn't just start un/installing drivers for no reason initially, I'm guessing, right?!? Between your resent BSOD error(s) (where your thread ended with little more than what seemed like a PARTIAL fix) and your new audio device/driver issues (which you used a third party driver installer app for I believe - which is really not advisable - as the results of using said software help illustrate), you must have had something initiate this problem. And malware was a very possible candidate.
From your lack of response to my bit torrent question, I am going to guess that would be a yes? The "detected files" from the MBAM scan appear to be for a music/file share?? and the kmsemulator.exe file I suppose was for unlocking Office. Just be aware this file is often a Trojan that may work just fine, but can infect your system without realizing it until some point in the future. The other I have no experience with, and may also carry malware. I would recommend their removal both for your system's security, and per the rules of Seven Forums.
Do the drivers require installation in a particular order? Yes, initially they did, and if you changed other NON-audio drivers around, then it would be best to reinstall the drivers from the manufacturer's website in the following order:
1. Chipset (MOBO) Drivers*
2. Video Drivers
3. Sound/Audio Drivers
4. Network Drivers
This will be most relevant if you altered the chipset drivers*, otherwise the chances of it fixing the problem are very low. Possibly the driver installation application you were using did change these, and so yes I would install all the newest drivers in the aforementioned order. (followed by any other drivers you might also require. But install the drivers manually one at a time and reboot between each.) You can preform a system restore to fix any driver that might cause a problem after rebooting, and you'll know which one it is that way.
As far as your antivirus program, I would use something else. I would recommend something that saps little system resources yet is very effective (and free) Microsoft's new Security Essentials (MSE) is a really good candidate for you. Also Avira (or Avast! if you prefer it). All are lightweight, effective and windows firewall used in conjunction with them is effective protection.
Would your current A/V software be the cause of your problem? Possibly the initial cause leading to the BSOD or other error which started the driver shuffling. I don't mean to say it is not a good antivirus software suite, but I would still recommend changing (and of course I know you could tell somehow with McAfee, that it wasn't scattered across your hard drive, but if you did just use the smart uninstaller app, [and your had used McAfee's trial initially] believe me, it most definitely had plenty of parts and relics left on your drive. I would find the removal tool by your A/V application at it's vender's web-site and follow their directions if you do uninstall the software as I recommended.)
Now my McAfee site Adviser is gone as well
Yes because that was part of the software that IS the McAfee Suite of tools. Many A/V apps offer similar site filtering/Notifications, or if you really felt it necessary to your web experience, you can get just the site adviser from McAfee. But I would wait until this process is finished, and you have a working system again. Then once a restore point(s) is/are made, you can reinstall whatever you must. (you should also make a backup image once it is working perfectly, for an easier fix if this or something else happens again one day)
Collectively this this your best chance, short of the clean install you are not comfortable with (as you mentioned much earlier)
I hope this helps!
If you would, please let me (and anyone else who reads this thread in the future) know how it turns out.
Mike :)
Biostar TA790XE3
Onboard
Sorry for not answering that..Yeah I am using μTorrent sometimes...
I will try to remove those keygens (or at least place them on another hdd) and see if something gets fixed.
The one is for Office as you said and the other is for the Internet Download Manager software (speeds the downloads).
For getting a different anti-virus software, I would prefer staying with the same because ZoneAlarm is also a firewall and works very well for me and I trust both functions.
Ok now for the drivers, I would love to install them again with the correct order.
But I don't know how to find each one of them and what category they belong to and what sites I have to download from.
That's why I have used DriverMax to get the job done and by not knowing about the drivers having an order to be installed it caused me serious problems.
Can you help me in installing the drivers again?
Should I visit the Dell website and find them categorized for my model? I guess that should work*.
This article could help: http://support.dell.com/support/top...t?c=us&docid=268873&doclang=en&l=en&s=gen&cs=
*I have noticed that they have some drivers for my model that I won't need. Like the AMD driver I don't need it, I have a GeForce GT. How do I make sure I download only the required ones?
Dell Inspiron N5110
4096MB RAM
Hi Chris,
I apologize for the late response, I didn't get a notice from your post (or lost it somehow.) Have you had any luck correcting your problem? The link that you posted was right on target, and if you look closely at each item, it explains what category each driver can be found under.
That can be tough, considering you changed so many. I would just go down the list that is presented at the link you supplied rebooting between installs. (and rolling back if one causes trouble).
If you DO get back to "normal", or have since I talked to you last, I would backup a full image of your drive, so you can return to this state if future if other problems develop.
Again, your best bet is a clean install.
I would appreciate to hear how your situation turns out, for my own interests as well as for other people that may read this thread with similar problems!
Best of luck,
Mike :)
Biostar TA790XE3
Onboard
Let me inform you how it turned out.
I guess I misunderstood the problem.
What the problem was from the first place?
Strange loud noises could be heard from my laptop's microphone.
What did I do to test it?
Went to Recording Devices > Microphone Array Properties > And chose "Listen to this device"...
That was WRONG.
Sure the same sounds could be heard by other people (contacts on Skype) but testing it like this it was a mistake.
When I updated the audio drivers, the problem MIGHT have been fixed at some point although I think I didn't test it over Skype (how stupid) and continuing testing it like I said.
I have been told by other people, that it is normal to hear these sounds if you click "Listen to this device" because there is a loop with the speakers and the microphone I suppose??
Anyway when I thought that updating the drivers didn't fix the problem, I did a System Restore to Factory State from Dell DataSafe Local Backup (Formats the system and returns it to the day that was purchased, with all the default drivers, softwares and Windows 7).
Maybe it is not a "clean" install because Windows 7 isn't removed.
Moving on...
I did again the "test" and surprised found that the problem remained!
I was very confused so I took the laptop to the "technicians" (that's what they call themselves :sarc:).
Surprisingly once again, they told me that there wasn't a problem (Although I think they change the Audio Jack card?? Something like that I think. I also mentioned the other problem with the speakers, maybe that's why. - They also got me a scratch near my mouse pad area!)!
So they told me to check with Skype, I did and everything was OK.
I was amazed how stupid I was on solving the problem.
To summarize:
Problem: Strange Loud noises coming from Speakers when using the Microphone, talking with other or recording alone.
Possible Solution: Updating the Audio drivers (If not all drivers).
Solution: Do a System Restore from a day before the problem occur, Do a Factory System Restore or do a clean install of the Operating System.
SOLVED
Hope this helps other people in the future.
However...
Even with the default installation some problems still remain.
The speaker problem:
When the Audio levels are over 50% the speakers are shaking like an old radio with bad music quality. Happens to most of my music. Doesn't occur using a headset though.
"Technicians" started to told me that this model has the best sound, better sound quality than other laptops and all that, instead of actually try to fix the problem. I didn't give any attention to that as I was focused on the microphone problem.
Should I try starting a new topic for that?
Not to mention...
Wifi (Wireless Network Connection):
I had this problem before.
When wireless connected with a router to connect to the Internet my laptop randomly disconnects and connects again when I hit "troubleshoot this problem". Sometimes the wireless connection is not available at all and I have to restart the laptop to get it back working.
I am not sure if it is the router's fault (Linksys) or my Laptop's.
Probably it's my Laptop because the Wireless Network Connection disappears sometimes.
Had this problem before, but I don't remember if I had it with my other router.
When Windows tries to fix the problem it says that a driver may be having problems.
I can't find any information on the Internet about this problem.
Thank you very much for your help and patience!
Dell Inspiron N5110
4096MB RAM
Also a recommendation for other people:
If you want to update your drivers use Windows Update from Control Panel as it often has the latest or at least the most working driver versions. To avoid driver problems you should avoid using a third-party software for updating them.
I want to ask one more question.
When I plug a headset (with microphone), a pop up window appears from the IDT application asking whether I plugged in a Mic or a Line in. I can find that quite annoying as well. Is there a way so my laptop recognizes automatically the Mic from my headset and stop the annoying application from starting?
Dell Inspiron N5110
4096MB RAM
I fixed this exact same situation by these steps:
  1. goto windows explorer at:
    "C:\Program Files\IDT\OEM\Dell"
    ( note your speakers may make a beep/scratch/pop sound, this is normal and ignore it )
  2. you 'should' see the file "IDTNGUI.startup"
  3. copy that "IDTNGUI.startup" file and paste it one folder up:
    "C:\Program Files\IDT\OEM"
That should make the IDT Control Panel immediately come up the next time you try to access it and in my case I did Not have to reboot, it worked immediately. NOW I HAVE MY EQUALIZER BACK :D
Hope this helps someone :)
XP Pro SP3 || Windows 7Pentium-D || intel Core i5 3.2GHz ( 2 cores w...4GB DDR2-800MHz || 4GB DDR3-1600onboard nVidia Geforce something or other
Acer || Meeeee
Pentium-D || intel Core i5 3.2GHz ( 2 cores w/HT == 4 cpus )
Acer || ASUS
onboard
1 21" crt
1152 x 864
500GB sata2 Seagate 7200.12 || 1TB sata2 Seagate 7200.12
dont know || Ultra
Acer || My old one
fans || nicer fans
Acer || Microsoft <-- I LOVE this KB ^^
Acer || Microsoft <-- I LOVE this mouse ^^
Comcast || Comcast
Companion PC || Main PC
I use these computers primarily for video game development; when I get my first release ready I'll let you know :-)
O/S Exp:
DOS, Windows 3.11 for workgroups, 95OSR2, 98SE (fav), XP Pro SP3 (fav), Windows 7 Home Premium (fav, ohh wow!!)
I have a copy of vista that came with my Acer but felt more comfortable with XP so I rebuilt it with XP Pro SP3
I don't know p
