AC'97 Sound (Microphone Device) Suddenly Not working
zeekz
7:51 AM
First post :)
OK, so here is my problem (Specs and Already tried solutions below):
I was using skype and my microphone was working perfectly. So, I go downstairs, get a drink and return. Only to find that my microphone is suddenly broke. Now it's not the microphone it's self, It works on my laptop, and I have plugged in 3 mics and they all render the same problem.
Basically, whether the mic is plugged in or not Windows reports that the mic is picking up sound (Green bar is FULL all the time). This happens on stereo mix, mono mix, line in etc.
My Audio however works fine. I have tried front and back jacks, no difference.
Although windows reports picking up sound, no sound is being processed (As tested through Skype, Sound Recorder and FRAPS). I did not change any hardware configs, as I went downstairs for literally 2 minutes. If I mute it however, the bar reduces to nothing (no sound being picked up).
Solutions that failed:
Re-plug in mic
Plug into another jack
Try different mic
Update Driver
Rollback driver
Delete driver, use driver sweeper and install driver
Disable and then enable in BIOS
Change the Sample Rate (Tried every single one)
Mute and unmute everything in the audio options and move all the sliders.
Turn Mic Boost on/off
Use windows troubleshoot (Found no Problem)
If somebody could please help me I would be so grateful. I am tearing my hear out in rage xD!
Specs:
Windows 7 x64 Ultimate
6GB RAM
HD 4670
AMD Athlon 64 x2 5200+ 2.7GHZ (2 Cores)
650W PSU
Thanks!
Unplug the mic and reboot. Plug it back in after Windows starts and see if works.
Windows 7 Pro-x64i7-2600 3.4GHz - 3.8GHz Turbo8Gb - 2x4GB, Muskin 991770 PC3-1333Integrated Intel HD 2000
Built 2/11/2011
Windows 7 Pro-x64
Intel DH67BL-B3
Integrated Intel 10.1 HD, RealTek ALC892
Asus LCD VH222H, Haier HL24XSL2a
1920x1080, 1920x1080
Crucial SSD C300-128Gb,
Western Digital WD5002AALX - 500Gb,
Western Digital WD7501AALS - 750Gb
Seasonic 650W 80+ Gold Modular
Rosewill Defender
Stock CPU, Four 120mm case fans, PCH fan added
Logitech EX100 Y-RBH94 Wireless
Logitech EX100 M-RCE95 Wireless
3.0/1.5 Mbs
Microsoft Internet Explorer 11
Antec Veris Premier-Multimedia IR Station,
Cyber Accoustics-3602 Speakers,
AFT XM-5U Card Reader,
Hauppauge TV-HVR-2250,
Sony LX300 USB Turntable
This may sound nuts, but are you sure the mute button on the headset itself is not engaged? This has happened to me on more than one occasion when talking on Skype. I get involved in conversation and accidentally engage the mute button on the headset.
Windows 7 Home Premium 64 bitIntel Pentium E5700640GB HDDIntegrated Graphics
Acer Aspire AX3910-U3012 PT
Intel Pentium E5700
640GB HDD
Integrated Graphics
Integrated Audio
Acer
I rebooted and now the green bar problem is gone. It wont pick up the mic at all now. Ima enjoy my christmas and then get back to this. Merry christmas all :)
