Windows 7: Sound Blaster X-Fi Xtreme Audio: Speakers pop when I click some things
14 Mar 2016   #11
spacetop
WIndows 10
Did you ever resolve this? I have this going on for years as well.. I just bought a new PC and moved my XFI to it and it's the same thing all over again. This time it's Windows 10 and not 7 like before. I'm connected via optical out to my Logitech Z-5500.. As soon as sounds starts it pops loudly and then plays fine. The only thing I was able to do to "kinda" prevent it is to play some audio file on the loops with 0 volume then it doesn't pop because it thinks that sound is already "started".. soooo annoying..
No sound on Sound Blaster X-Fi Xtreme audio
Hello guys, Last night I was helping to a friend and connected his computer with mine by KVM switch. We had done all, I got unplugged KVM switch,reconnected my monitor,KB an mouse.Everything was just fine. After a while,without reason, (or there may be some reason which I can't figure...
Creative Sound Blaster X-Fi Xtreme Audio PCI - microphone problem
Hello there. Yesterday i've installed this sound card and everything works fine but no microphone. I can see it in control panel but it doesn't work. Mic is fine as i was using it before. I have Win 7 64bit. If you have any idea what can cause the issue please help, if nothing will work i will...
Creative's Sound Blaster X-Fi Xtreme Audio PCI Express
Hey mates, Today I bought and installed a new sound card. Creative's Sound Blaster X-Fi Xtreme Audio PCI Express. More information about the card can be found here: Creative Labs Online Store (Europe) | Sound Blaster | Buy Creative PCI Express X-Fi Xtreme Audio Anyway, this card is a...
Sound Blaster X-Fi Xtreme Audio 70SB104000001
Hi guys I treated myself to a new pc but the only thing missing is a soundcard. Im looking at Sound Blaster X-Fi Xtreme Audio 70SB104000001 Creative Labs Online Store (UK) | Sound Blaster | Buy Creative PCI Express X-Fi Xtreme Audio I am running windows seven home premium 64bit and i...
Sound Blaster X-Fi Xtreme Audio / Creative.com
Ok, so I read the stickied topic about the X-Fi Xtreme Audio driver, as I think this maybe a part of my computers less-than stable condition after recent Fresh Installs of Windows 7 Home Premium 64bit. I got 2 things... 1) When I install Drivers off my CD, I get a SpiRunE.dll error about a...
Hi, im running windows 7 (7100) 32 bit. Ive got Creative Sound Blaster X-Fi Xtreme Audio in, ive downloaded the xp, vista and 7 beta drivers from creative, they either say driver version not found OR they say the device isnt plugged in properly, which it is having run it with xp. The only thing i...
