How do i fix my multimedia audio controller & pci input device driver?
Sabracx378
12:40 PM
Indonesia
My mobo is foxconn G31MV-K, Socket 775
Processor : Intel(R) Pentium(R) Dual CPU E2180 @2.00GHz @2.00Ghz
RAM : 1.00 GB
OS : Windows 7 Ultimate 32-bit
Audio: 5.1 HD audio by Realtek® ALC662-GR
The main problem is the multimedia audio controller & pci input device in the device manager always have a sign of (!) and when I check the properties, it's said code 28(If i'm not mistaken). I have installed the driver from the manufacturer, but still the sound won't come out.Could anyone help me please?I'm not too good in computer stuffs:cry:..Thanks:)
Windows 7 Ultimate 32bit
Install the motherboard Chipset Drivers and then the sound drivers. That usually takes care of problems such as this.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Ok, I'll try it. Thanks
So sad, I already install the system and chipset driver also on-board audio driver. But still, the sound won't come out, any other suggestion?
There is some hardware problem or the right drivers are not being installed. The chipset drivers define (identify) all the hardware devices on the motherboard. Since you apparently have at least two hardware devices with problems it goes back to either a motherboard hardware problem or chipset drivers. On a Foxconn motherboard (which are used in many Dell's and Foxconn makes many Intel motherboards) the chipset drivers MUST be installed BEFORE installing the sound drivers and some other devices or the drivers will not install and the Code 28 says the drivers are not installed.
Reset the BIOS and see if that helps. It's a long shot but worth a try.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
