No Audio Output Device is Installed 201112311600
eiger3970
11:13 PM
No Audio Output Device Installed. Red cross on Volume icon in task bar.
1. MOBO sound card won't work.
2. Installed sound card won't work.
3. I posted this previously and installing the sound card fixed the issue.
Unfortunately, I reinstalled Windows 7 and now no sound works on the MOBO or sound card?
Update Driver Software cannot find driver software for my device.
I have posted here but no one will read it on page 23. http://www.sevenforums.com/sound-audio/199861-no-audio-output-device-installed-23.html#post1721472
Windows 7Intel Pentium 4 @ 2400 MHz1024 MB (1 x 1024 DDR-SDRAM)NVIDIA GeForce 7600 GS (Microsoft Corporation...
Self built pc.
Unspecified P4M266A-8237
NVIDIA GeForce 7600 GS (Microsoft Corporation - WDDM)
Onboard VT8233/A AC'97 Enhanced Audio Controller
Samsung SyncMaster - 17 inches
1280x1024
SAMSUNG (400 GB)
WDC (80 GB)
VIAP4X SLIC-MPC 450 Watt
Unknown
Processor fan 3750 rpm
Belkin ergonomic
Logitech laser
Cable up to 8Mbps
PC runs at about 59.9 centigrade.
If you are certain you are using the same driver that worked before, and it was installed after windows was allowed to install all the drivers initially (often several to many reboots) then you may want to try to rule out a hardware problem - even though it is new. I would try to download a Linux OS that can be run straight off a CD/DVD such as Ubuntu, and run it without installing anything to your hard drive. Check whether or not it will produce sound using your sound card.
Might want to try (with the computer unplugged) unplugging, and reseating the sound card, to be sure it is making perfect contact (and use the fastening screw, which may people will omit, to hold the card in place when un/plugging connectors)
Let me know the results!
Best of luck!
Mike :)
MS Windows 7 Home Premium SP1 64-bit (Family ...AMD Phenom II X6: Black Ed 1090T - AM3 / 3.2G...2 dual ch sets OCZ DDR3 PC3-10666 Platinum 13...Onboard
Custom self build - Desktop
MS Windows 7 Home Premium SP1 64-bit (Family Pack Lic.) Upgrade
AMD Phenom II X6: Black Ed 1090T - AM3 / 3.2GHz / 8MB
Biostar TA790XE3
2 dual ch sets OCZ DDR3 PC3-10666 Platinum 1333MHz 8GB total
Onboard
Onboard 5.1 channel HD
SyncMaster "Legal-sized" LCD (rotatable)
unknown (8.5"x15")? pixels are not known
HDD1: WD RE3 Enterprize [p/n: WD500ABYS-NDW]
________SATA-II (3Gb/s) 500GB/7200rpm/16MB
HDD2: Deskstar 7K1000.C [p/n: HDS721010CLA332]
________SATA-II (3Gb/s) 1TB/7200rpm/32MB
Antec 900W mATX 20+4 w/6-8SATA;2MLX;4x6(+2)PCIe[p/n HCG-900]
Mid 10-bay tower - free space design interior & well vented
CPU HS cooler, 14.5" Case-sysfan1, dual sysfan2, exhaust
Blue Star Ergonomic - ps/2
LED coorded w/v. roller wheel - ps/2
GbLAN 10/100/1000 & WLAN - on T1 (Peer Network)
Harmon-Karden speakers (L,R @ sub)
APC (Lead/Acid Batt backup UPC+Surge protector+etc)
Sony DVD SATA(300) - RW DVD/CD SATA-II(300)
Self built pc.
1280x1024
SAMSUNG (400 GB)
WDC (80 GB)
Unknown
Belkin ergonomic
Logitech laser
Cable up to 8Mbps
Hello eiger3970,
So itWAS the driver! That's great that you got it to install correctly this time - CONGRATULATIONS!:party:!!!
you may want to at minimum make a note of the driver versions for the audio driver(s) (and the chipset driver) just in case an incorrect driver gets installed in the future and you can't roll back.
IDEALLY, now that it is working perfectly (from what I am hearing, anyway) I would make a full image backup of your system, so that if you ever run into any problems in the future - you'll be able to recover much faster to a working state, without the hassle of locating all the right drivers, and so forth!
Here's a tutorial on how to do that, it's both simple, and will be well worth your time and space on whatever storage media you decide to use: Backup Complete Computer - Create an Image Backup. I highly recommend this step!
Either way, I'm glad to hear it's fixed, eiger! Thx for reporting back your results and checking solved too! I hope you have a Happy New Year (esp. now with a working system for a gift!)
Congrats again!
Mike :D
Biostar TA790XE3
Onboard
After reinstalling Windows 7 64bit due to a HDD no longer being recognised...I'm back to the no audio issue.
I have downloaded the driver, but now the error is:
Problems found
Hardware changes might not have been detected.
Also another error:
Windows was unable to install your Multimedia Audio Controller.
Windows could not find driver software for your device.
Also another error after running the downloaded audio device driver:
Device driver software was not successfully installed.
Multimedia Audio Controller. No driver found.
Please help.
Self built pc.
1280x1024
SAMSUNG (400 GB)
WDC (80 GB)
Unknown
Belkin ergonomic
Logitech laser
Cable up to 8Mbps
Anyone with any ideas?
My MOBO sound won't work.
My sound card put in to fix the sound won't work?
What is going on.
The same error as per the above post still happens.
Self built pc.
1280x1024
SAMSUNG (400 GB)
WDC (80 GB)
Unknown
Belkin ergonomic
Logitech laser
Cable up to 8Mbps
Well, I've now installed a different motherboard ASRock G41M-VS3 and the same problem?
A red cross on the Volume icon in the taskbar?
Control Panel\Sound says No audio devices are installed?
But this is another motherboard which worked fine in another tower.
Any ideas?
Self built pc.
1280x1024
SAMSUNG (400 GB)
WDC (80 GB)
Unknown
Belkin ergonomic
Logitech laser
Cable up to 8Mbps
