Sound on Windows 7 Ultimate 32-bit not working?
  1. Posts : 3
    Windows 7 ultimate 32-bit
    Since yesterday, I logged onto youtube and noticed my sound was not working at all. I have tried disabling my sound and enabling it but it doesn't resolve the problem. I also tried trouble shooting the sound and it told me to plug in the speaker but I have internal speakers, it also said "The peripheral does not appear to be plugged in. Check the connection. Proceed to next step to finish."
    I have no idea on how to resolve my sound issues. This has never happened before.
  2. Posts : 529
    Did you try external speakers ????
    Maybe the internal one's are broken
  3. Posts : 3
    I don't have any external speakers anymore. Is there any possible way that I accidently turned them off or disabled any speakers
  4. Posts : 529
    are you sure your audio isn't muted ?
    als check device manager if your audio driver is enabled.
    and yeah maybe try updating the driver it could help (which audio card do you have ?)
  5. Posts : 3
    It says it is enabled under 'High Definition Audio device' and then when I double click on that a pop up comes up and says:
    "MMC has detected an error in snap-in. It is recommended that you shut down and restart MMC" What does that me :\
  6. Posts : 529
    Try rebooting your PC ?! maybe then your audio works again
