Windows 7 Forums Search
Windows 7 - No ingame sound when using skype or teamspeak. HELP!
01-04-2012   #1
Windows 7 64 bit
I am running an HT Omega Striker 7.1 sound card, and the in game sound, and built in voice chat of BF works fine. When I try to play any game with Teamspeak or skype running, I lose all in game sound. I have already checked my mixer icon, and I have the communications tab set to do nothing when windows detects communications activity. I am at a loss, and dont know what else to do. HELP!
01-04-2012   #2
Couple of suggestions I found:
"I had this issue and I solved it. TeamSpeak 3->Settings->Plugins (Ctrl+Shift+P) and uncheck the "Volume Control" plugin. I haven't had a problem since I did this. "
Launch Teamspeak first
Source: no sound in game when using teamspeak
01-05-2012   #3
Windows 7 64 bit
I had already done that, and tht didnt work, but thank you. I am having the same problem with skype too. I dont get it. I can use any voip program perfectly, I just cant get in game sound when Im using them. Ive been through all my sound card settings too. Im going crazy.
 No ingame sound when using skype or teamspeak. HELP! problems?
Similar Threads for: No ingame sound when using skype or teamspeak. HELP!
Sound in speakers while on skype Sound & Audio
Solved Microphone works on Teamspeak, Skype etc. not on GFWL. Sound & Audio
All other sound Stop playing when I talk to someone on Skype Sound & Audio
Making TeamSpeak/Skype use a single stereo channel Sound & Audio
Solved - Skype does not see sound card in Windows 7 Sound & Audio
