Solved Audiophile 2.1 sound system for Xonar D2X sound card.
0pp9iuy
7:53 PM
I have given up on getting a good 5.1 or 7.1 sound system for my pc since it requires a receiver and all.
What I am looking for right now is a 2.1 sound system that can be directly plugged in to my Asus Xonar D2X sound card. The system should have a really decent subwoofer with tight and deep bass. As for the speakers, they should be able to produce crisp sound at high volume.
My current sound system can no longer handle high pitch sound without the buzzing :(
I am no expert in this matter, but I've been looking around a lot with no luck.
No real budget limitation, if its worth it I will get it ;)
Thanks in advance,
Sylo
Windows 7 Ultimate x64Intel i7 970 (6-Core)G.Skill Ripjaws 8GB (2x4GB) CL7Nvidia GTX 580
Scan
Gigabyte GA-X58A-UD5
Nvidia GTX 580
Asus Xonar D2X (7.1 Ch)
Insignia 32" Full HD LED-LCD
1080p
Crucial C300 128GB SSD (Main)
WD Black Caviar 1TB 6Gb/s HDD
Corsair TX950W
CM HAF X
Corsair H70
Logitech Wave K350
Logitech Wave M510
You could look at something from Audioengine, M-Audio, or the Klipsch 2.1 system. Read plenty of reviews though. I know you want 2.1, but if I were buying now I'd probably go with the M-Audio Studiophile AV 40.
My 2 cents.
Windows 10 Pro 64 bitCore i7 6700K Skylake 4.0GHzCorsair Vengeance LPX DDR4 32GB 3000MHzAsus Radeon RX480 Strix 8GB
Wordsworth 5000
Asus Z170 Pro
Asus Xonar DSX
HP 2709m
Intel 600p M.2 PCIe NVMe SSD 512GB; Intel 335 SSD 240GB ;Western Digital Caviar Black 1TB
Thermaltake Toughpower Grand Platinum 850W
Lian Li PC-B70
CPU-Noctua NH D15, GPU-Stock, Case-Noctua 2x140, 2x120
Microsoft Natural Ergo 4000
Microsoft Wireless Optical 1000
Cable
HP bd 340,
HP bd 240,
Klipsch Promedia 5.1 THX
I've been looking around at Audioengine and M-Audio websites to realize that I will have to make my own 2.1 system by getting speakers and pairing them with a sub, so I'm down to two options:
1. Audio engine:
Speakers: Audioengine 5+
Sub: Audioengine S8
2. M-Audio:
Speakers: M-Audio BX5 D2
Sub: SBX10
I am leaning towards Audioengine, I like the additional audio input.
All have really good reviews, so I still don't know which to choose.
Thanks,
Sylo
Scan
Nvidia GTX 580
1080p
Corsair TX950W
CM HAF X
Corsair H70
Logitech Wave K350
Logitech Wave M510
Looking at the Amazon 1 star reviews on the M-Audios I don't know if I'd go with those. Someone can always get an electronic item that is bad, but when I read reviews speaking of quality control problems a red flag goes up because of my experience with the Klipsch Promedia 5.1s. M-Audio has a one year warranty, Audioengine a three year warranty.
My experience with the Klipsch Promedias was like many others who bought them, and would make me pay attention to the worst reviews where people have had quality issues. The Klipsch forums are still rife with stories of certain components of the BASH amp going bad. I had two systems quit within weeks which were replaced under the warranty I bought from CompUSA. The third set quit after about 3.5 years and I had it repaired a couple of years ago by a third party.
It's difficult to find quality speakers (both sound and longevity) to use with a computer unless you just go with a receiver, but then you're not using the computer except as a source. The worst reviews at Amazon on the Audioengines speak of muddied bass. I'd probably give the Audioengines a try since you get a 3 year warranty and the 30 day audition. If they don't sound good to you send them back and try something else.
Wordsworth 5000
Asus Z170 Pro
Asus Xonar DSX
HP 2709m
Lian Li PC-B70
Cable
HP bd 340,
HP bd 240,
I think I will give the Audioengines a try. hope they are as good as they say.
I'll get the 5+ speakers and the S8 sub and see how they sound together.
Thanks man
Scan
Nvidia GTX 580
1080p
Corsair TX950W
CM HAF X
Corsair H70
Logitech Wave K350
Logitech Wave M510
It has a been more than a week since I got my new Audioengine sound system ,5+ and S8. I believe I'm past the break-in period. I have my sub connected to my speaker through the variable output connection.
I must say that it was a surprise for me when I first listened to a FLAC track; There was no humming or buzzing from the speakers and the sound was way crisper than my previous sound system (Logitech X-540). the sub is way louder and packs more punch with a lot less boomyness. I can practically shake the house. lol.
What I liked most about the speakers is the additional input. I can plug in my iphone whenever I feel like it. No need to have my pc on to enjoy some songs. Also I always though it was impossible to get a decent surround sound system without a receiver but I can just buy another speaker pair (i.e. Audioengine 5+) and connect them to the side and rear outputs in my soundcard and BAM! surround. Only it would be 4.1 or 6.1.
Thanks again,
Sylo
Scan
Nvidia GTX 580
1080p
Corsair TX950W
CM HAF X
Corsair H70
Logitech Wave K350
Logitech Wave M510
