Solved Srs audio essentials & Srs hd audio lab?
asser
12:01 AM
Hi
I am sorry to say that the new "hit" from SRS LABS is not as good as their first baby(SRS HD AUDIO LAB),both soundquality and interface is super,you can actually hear when turning srs audio processing on/off,this is allmost impossible with audio essentials.
I have three srs products on my laptop(onely one at the time) the products is:srs audio fusion divx version,srs audio essentials and last but not least srs hd audio lab,all purchased(full)versions.
SRS TECHNOLOGY has a bright future a head of them.
Srs hd audio lab is the mother of all audio plugins,it is an brilliant DSP plugin.
Kind Regards Asser:p
windows 7 home premium 64 bittintel pentium t4500 2.30 ghz penryn 45nm tech...4,00 gb dualchannel ddr2 398mhzmobile intel (R) 4 series express chipset family
ms windows 7 home premium 64 bit sp1
intel pentium t4500 2.30 ghz penryn 45nm technology
acer jv50 (u2e1)
intel r high definition audio hdmi (srs hd audio lab)
i think in same way. sound quality is worse in Audio Essentials than HD Audio Lab. Why they create a worse software or are we doing something wrong?
Windows 7 Ultimate 32 bit
Agreed, the old one has much better bass. But the new is still pretty awesome, clear and clean. Actually works better on my home computer since my speakers have their own bass boost - demo version. The actual paid version I have at work but it isn't bassy enough - can I run anything else with it to boost the bass? Thanks if anyone knows! Mk
intel
