I Need Help Choosing a New Sound Card
Bleu
8:38 AM
I am listening to most of my music on my computer these days. I'm using lossless files and have been wanting to buy a new set of headphones for ages. However I think this money may be better spent on a new sound card as I'm currently using the built-in card that came with my motherboard. I know my PC may not be the best computer in the world but would installing a sound card give me better sound quality?
I have a Gigabyte GA-X58A-UD3R Intel X58 Socket 1366 8 Channel Audio ATX Motherboard. I know it's quite a basic motherboard but don't feel the need to upgrade it yet link here.
I'm not sure what information you need so I'm just going to list some things. I have a Antec Dark Fleet DF-85 case, Intel Core i7 950 3.06GHz CPU and a XFX HD 5870 1GB GDDR5 Dual DVI HDMI DP Out PCI-E graphics card.
Could you please recommend a compatible sound card for me? I listen to a lot of music so sound is really important and I'd want the best possible sound from my PC. I don't really have a budget but ideally like something in the range £200 or under would be great.
I'd really appreciate any suggestions as to what sound card to buy. Also if possible a link to a stockist in the UK, although this isn't crucial.
Finally is it hard to install a sound card? A friend put my machine together for me and I don't really want to bother him if I could slip it in myself without too much difficulty.
Thank you :)
Windows 7 Ultimate 64Intel Sandybridge i7-2600K Quad-Core (3.40GHz...Corsair Vengeance 16GB (4x4GB) DDR3Gainward GTX 570 Phantom 1280MB GDDR5 x 1
N/A (Custom Build)
Intel Sandybridge i7-2600K Quad-Core (3.40GHz, Socket 1155)
Asus - P8Z68 V Pro Gen 3
N/A
1920 x 1080p
Crucial 2.5" 64GB Real SSD SATA 6GB/s: OS - Windows 7
WD 1TB 3.5" SATA-III 6Gb/s Caviar Black Hard Drive - 7200rpm 64MB Cache x 4
WD 2TB 3.5" SATA-III 6Gb/s Caviar Black Hard Drive 7200RPM 64MB Cache x 1
External Drives:
WD My Book 1TB S
Antec TruePower Quattro 1200
Corsair Obsidian 800D
Corsair Hydro Series H100 CPU Cooler
Razer Black Widow "Ultimate"
Razer Deathadder Re-Spawn 3500DPI Infrared
Far too Slow
Optical Drives:
Pioneer BDR-205BK 12x BD-RE x 1
LiteOn iHAS124 24x DVD±RW DL & RAM SATA
All depends how much money you willing to spend. I personally have owned an Asus Xonar Essence STX ( about 140 £ ) along with Sennheiser HD 650 (270£). You can get some less expensive headphones like Grado SR 80i. (100£) However if you decide to go for Asus Xonar ( STX or ST ) or other descent sound card you just cannot be buying cheap headphones.
Hope it helps
Overclockers UK
Richer Sounds - The UK's Hi-Fi, Home Cinema & Flat Panel TV Specialists!
Superfi Online - UK's best supplier of hifi equipment including separates, systems and accessories. Purchase Home Cinema Equipment, DVD players, minidiscs, amplifiers, cassette decks, CD players, Digital recorders, personal stereos, speakers, turntab
Windows 7 Home Premium 64
Are you really going to hear much difference in the sound? Especially if you are going to be using headphones.
Nothing wrong with onboard sound these days.
Windows 7 Pro x64 -- PCLinuxOS KDE4 FullMonty...i7-875k @ Turbo - 7,6,5,5 - 3.6ghzCorsair CMD8GX3M4A1600C8 8gbAsus EAH5850 DirectCU/2DIS/1GD5
Windows 7 Pro x64 -- PCLinuxOS KDE4 FullMonty 2011
Asus P7P55D-E Deluxe
On Board
Samsung SyncMaster T220 - Panasonic VT30a 50"
1680x1050 -
Corsair Force 3 SSD 120GB x 2 ::
WD VelociRaptor 150GB WD1500HLFS x 2
Corsair HX-850 Power Supply
Coolmaster HAF 932
Corsair H50
Logitech Wireless MK700
Logitech Wireless MX620
Good enough for now
Voip. Insanely cheap phone calls.
Yeah. Xonar Essence has got a headphone amplifier built in. Combined with descent headphones sound quality is just amazing. Really nice experience having a listen with this setup. And on top of that is not extremely expensive.
Hi there
unless you want special sound effects for games most computer sound cards are MORE than fit for purpose these days when listening to music.
IMO your money would be BETTER spent on a decent set of cans -- say Sennheiser or Bose. Bose are expensive but they work fine.
Or :
Actually talking of Bose for around 85 GBP you can buy the absolutely EXCELLENT Bose 2 companion set of small PC speakers -- just plug the audio out of the computer into these -- these beat almost anything until you start getting into the 2 or 300 GBP range.
Companion 2 multimedia speaker system | Bose
Although it says 99 GBP here you can find these a lot cheaper.
Cheers
jimbo
Intel i7 Intel i5
8GB, 16GB
On Motherboard
Realtek HD audio
1920 X 1080
4 X 1TB SATA
Toshiba wireless laser
> 20MB up
Thanks to everyone for your replies. I do play games as well so I think I'll look into some of those soundcards mentioned as well as the speakers. I can't make up my mind on the headphones yet but will get something I like eventually.
Thanks again. :D
Grace. x
N/A (Custom Build)
N/A
1920 x 1080p
External Drives:
WD My Book 1TB S
Far too Slow
Optical Drives:
Just picked up the X-Fi Tianium HD (the HD part is important) and its really good. Supposedly built for Win7, and as far as Im aware, thats the only drivers it even has.
Much better than the old X-Fi.
Windows 7 Home Premium 64bitIntel Core i7 2700k8GB Mushkin Redline Ridgebacks @1866EVGA GTX570 SC
Custom (Self Build)
Intel Core i7 2700k
eVGA P67 SLI
EVGA GTX570 SC
XiFi Titanium HD
LG W2453V
Seasonic x750
Corsair 600T SE White
eVGA Superclocked CPU Cooler
Saitek Cyborg
Kaspersky
IE
LG BD/DVD
