help findin adapter to enable both 5.1 devices to connect but select 1
ello folks
i have an x-fi titanium soundcard with logitech 5.1 speakers that use 3x 3.5mm jacks ive ordered a set of roccat kaves which also use 3x3.5mm jacks.
what i would like to know is. is there some kind of cable or a switch box that i can plug all jacks in but select which device i want to use? so i dont have to keep swapping them at the back of my pc. or is the best thing to just use some 3.5mm jack extensions and mount them closer to me. then just swap the cables as and when??
any help is much apreciated folks. thanks in advance
