Sound Blaster Audigy
Zerolife
Banned
2:54 PM
seems a lot of people are having issues with the sound blaster audigy cards, me included. Im dual bootin windows 7 and XP, on windows XP my sound card works and everything, when i boot in windows 7, dosnt even detect my card. I have the driver i need to get it to work, its just not detecting it to begin with. Anyone have any suggestion to get it to work?
Windows XP
Windows XP
What driver are you using?
Ken
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
And which Audigy?
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
BTW
we could use your system specs.
Ken
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
im pretty sure my sound card is just Sound Blaster Audigy, when i looked it up on the creative site, thats what it was called. I just downloaded the newest driver straight from creative, supposed to be compadible with windows 7, atleast thats what they claim
not sure what specs ya want so could you be more specific? sorry, new to the forum lol
Windows XP
Windows XP
Reason for asking which Audigy is that there are two completely different drivers,
- one is for the Audigy 1, 2 and 4 series of cards
- one is for the Audigy SE/DE/LS/Value series of cards, and has about as much relation to the ones above as apples to oranges.
and one will not work with the other.
Computer specs; as in make and model if something like a Dell or HP, or list of components if custom built.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
I'm using Sound Blaster Audigy and using the drivers for XP just fine. I tried their latest download which lists Windows 7 but I think that driver package may be for more that one type of card. I got no sound with those. I also tried the Vista ones but they wouldn't install.
If you look at their Windows 7 driver availability chart, the driver for the plain Audigy is TBC (to be confirmed)
XP / Windows 7 Pro RTM
Haha! You peeked. Why so nosey?
motherboard: MSI Amethyst-M
cpu: AMD Athlon 64, 2200 MHz (11 x 200) 3500+
RAM: 1.5 gb DDR
exact sound card: Creative Audigy SE (SB0570) Sound Card
thats probably all that will be needed, rest is just video card and stuff ,that works.
my problem is that windows 7 wont even detect the card being inserted tho, i dont think having the right driver will fix that really, idk tho i could be wrong.
thats for being patient with me lol
Windows XP
Windows XP
In Device manager, is there under Unknown is there a multimedia device showing?
Also one reason for it not detecting the card can be down to having an unsupported chipset on the motherboard (ATI RS482), and using whatever Windows installed for chipset drivers.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
well it does show an unnamed multimedia device, but thats my broken internal sound card, whoops. It could possibly be my sound blaster, but how would i make it figure that out lol
idk much about chipsets, anyway i could fix that in windows 7? the sound card works in xp, im actually using it right now lol, if that means anything that would help u figure otu how to fix it lol
Windows XP
Windows XP
A quick check in the bios, and make sure that the onboard audio is disabled.
Just in case this is the driver you need,
Creative Sound Blaster audio driver 1.04.0090
After downloading use something like Winrar to extract the downloaded file. Once extracted open Device Manager, go to the multimedia device, right click on select "Update driver". Then,
1. select Browse my computer
2. select "Let me pick'
3. click on "have disk"
4. click on Browse and find the extracted folder and point it to the folder that contains p17.inf, will look like this,
SB24_PCDRV_LB_1_04_0090\Drivers\vista
Assuming the unknown multimedia controller is your Audigy that should get the driver installed. Give it a try and please report back whether it worked or not.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
omfg, that worked, thanks so much, now ill probably never boot in xp tho lol
Windows XP
Windows XP
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
How to fix your problem
hi
I had the same problem of my creative soundblaster not being seen in Windows 7.
What I did was
1. Go into Bios and disable onboard sound card
2. Shut down and power off your computer.
3. Take out the sound blaster, plug in the power and reboot your computer without the soundblaster card in.
4. Shut down your computer and take out power cable and then reinsert your sound blaster.
It should then be detected by windows 7
Then install the latest drivers and software from Creative and it should work.
Hope this helps
windows 7
windows 7
will give these 2 solutions a go in a few days time
windows 7 home premium 64 bitintel dual core e2220OCZ Gold Edition 4GB (2x2GB) PC2-6400C5 Dual ...
gigabyte ga-73pvm-2sh
OCZ Gold Edition 4GB (2x2GB) PC2-6400C5 Dual Channel Series
creative sound blaster audigy 7.1 se
Windows 7, LinuxAMD Phemon II x2 3@37501G Crucial 16668800GT OC (custom OC)
Windows 7, Linux
ASRock M3A770DE
1G Crucial 1666
Sound Blaster Live! (never changes!)
Vivitron 22"
1600x1200
Western Digital 120G/160G SATA
Maxtor 80G IDE
450w
Unknown
Custom Air cooled
Logitech M-BZ15A Laser
Cable 10mbit
Windows 7 Ultimate x64 Service Pack 1 (Build ...Intel Core 2 Quad Q6600 (G0 Kentsfield) LGA77...Corsair TW3X4G1333C9A 4GB PC-10600 (2x XMS3 2GB)ASUS nVIDIA GeForce 560
Windows 7 Ultimate x64 Service Pack 1 (Build 6.1.7601)
Intel Core 2 Quad Q6600 (G0 Kentsfield) LGA775 (FC-LGA6)
GIGABYTE GA-EP35C-DS3R (Rev. 2.1)
RealTek ALC885/889A/890
ChiMei CMV CT-730D 17inch (LCD Monitor)
1280-1024 60Hertz (Ture Colour 32bit)
2x Barracuda 7200.10 SATA 3.0Gb/s 160-GB Hard Drive ST3160815AS (AHCI)
ANTEC 750w Earthwatts
Thermaltake Shark (VA7000SWA ATX) Full Tower
Front 120mm fan (1400 RPM) /Rear 120mm (1400 RPM) blue LED
Labtec Media Desktop Y-SAD65
Razer DeathAdder 3G Infrared Sensor (1800DPI)
Telstra BigPond Elite Liberty ADSL2+ 24Mbps/256kbps
ASUS PCE-N13 802.11n Wireless LAN card
tried this today and it works, absolute legend.
the only thing is that 2 of the speakers sound a little bit crackly? i had this issue with xp on my old 5.1 surround set also, and now on W7 it does it with both my old and new set so maybe the sound card itself has a slight issue?
