Windows 7: Vinyl restoration help for Sony Sound Forge 10.0
28 Jan 2012   #11
restorationwiz
windows 7 ultimate x64
@ignatzatsonic behringer ufo 202 is not available but behringer uca222 is available will that do??
28 Jan 2012   #12
ignatzatsonic
Quote   Quote: Originally Posted by restorationwiz View Post
The UFO-202 is available here:
http://www.amazon.com/s/ref=nb_sb_no...nger&x=17&y=14
at Amazon, along with the UCA 222.
I have no knowledge about the UCA 222, but at first glance it looks like it has only 4 connection points, not 5 like on the UF0-202.
I suspect that missing connection point is a ground for a turntable, which you should have if you intend to connect a turntable to it.
Nor do I know if the UCA 222 has built in RIAA equalization, as the UFO 202 does.
All I can suggest is to drill into Behringer.com and google generally to find out what you can.
31 Jan 2012   #13
restorationwiz
@ignatzatsonic i managed to acquire a behringer ufo202 and iv hooked it up to my system... my garrard 6200c does not have a separate ground pin.. when i plug in my head phones and turn the volume of the behringer pre amp all the way up theres a huge bass hum .... and my recording software shows me an input present in the form of a square wave... ?? whats the problem??
31 Jan 2012   #14
ignatzatsonic
See post 2 in this thread from Fireberd.
I assume you get the hum even when not playing a recording, so it sounds like a grounding problem.
Sound Forge with Windows 7 Not Recording
I have Sound Forge 9 installed on my desktop computer and it works fine. I realise thereís doubt over compatibility of Sound Forge 9 with Windows 7 but Iíve installed it on my new Windows 7 laptop (Acer 1410 64 bit) and it works as normal - except it wonít Record. I can send a music file to...
Sony Sound Forge Not Launching After Install
Hey guys, I just recently bought Sony Sound Forge 10 at a local computer store. I installed it on to my computer, and now it will not open. I have tried running it as "administrator" and that didn't do anything. I tried restarting my computer still nothing. I also tried reinstalling it and...
Software
Defining tracks with Sound Forge
I am using Sound Forge 9.0. I have tried several times to burn a CD from an edited file. After about 15 minutes I get tthe message "The disc burn completed without errors." But there is nothing on the disk. I know the cd burner works as I can copy the files using window, though it comes through...
Sound freezes system (Via Vinyl AC'97)
Here's a problem that's driving me nuts with an otherwise excellent OS. I'm running Win7 (RC1, 32 bit) on a Fujitsu-Siemens Amilo A7640 notebook (1GB RAM, Mobile AMD Sempron 3000+), which uses VIA Vinyl AC'97 (VIA VT1612A AC97) to playback sound. The system has a habit of freezing when...
Sony Sound Forge 9.0e
Can anybody confirm if Sony Sound Forge 9.0e works well with Windows 7? Thanks :)
Software
Sound Forge Audio Studio 9d & Audacity
Hi All, I'm new to this forum and appreciate all of the great information on switching over to Windows 7.:D I use Sony Sound Forge Audio Studio 9d and Audacity and I can't find any information on their compatibility with Windows 7. Anyone have any information on whether or not these...
Software
