Windows 7: Sound problem. Plz help.. images attached..
23 Jan 2012   #11
mitchell65
You said in your first post that you have upgraded your computer. Can you be more precise? What exactly have you upgraded the hardware or the OS?
23 Jan 2012   #12
NRT
Windows 7 Ultimate 64-bit SP1
ya... upgraded my hardware.....
23 Jan 2012   #13
Dwarf
Windows 8.1 Pro RTM x64
If not as listed in your specs, what is it now?
23 Jan 2012   #14
NRT
yes.... its listed in the specs.... I'm on a surge of buying a new motherboard as u (dwarf) said to go with Gigabyte... but i want to assure its my ASUS' inbuilt sound problem (listed above)...
23 Jan 2012   #15
NRT
Quote   Quote: Originally Posted by NRT View Post
is it a sound card problem.. ?? or it cud b a virus ?? plz help...
any reply on this ??
23 Jan 2012   #16
Dwarf
It could be either or both. I've no experience with VIA audio (all my systems have used Realtek), so it might be pertinent to see if a VIA audio user can offer any advice.
23 Jan 2012   #17
mitchell65
Short of putting a spare PCI sound card in it is difficult to tell!
23 Jan 2012   #18
NRT
Quote   Quote: Originally Posted by Dwarf View Post
i've formatted my computer atleast 3 times to get rid of this problem, of the thought of a virus... scanned with malwarebytes and found no infections though..
23 Jan 2012   #19
Golden
Microsoft MVP
Windows 7 Ult. x64
I doubt this is malware-related : it certainly points to a hardware/driver issue. has the sound ever worked on this system before? At which point did it stop functioning properly?
Regards,
Golden
23 Jan 2012   #20
mitchell65
Have you tried the mundane things like, trying the speakers in the front speaker socket? Trying a headset in the front and back sockets? Trying your speakers in another PC if this is possible?
Sound coming from speakers when headphones attached
Hi, I have the following problem with Dell Inspiron N5010 with Windows 7 Ultimate 64 Bit: When headphones are connected to the headphone jack, the laptop speakers will not disable. The laptop recognizes headphones (test sounds are coming through) and they can be used for communications, e.g....
Stuttering Sound and Images and Cpu Usage sporadically raises
Sporadically my computer stutters in sound when listening music and whether or not i'm in game my sound and game stutters. my FPS drops and it just sounds like bzazaghga. My CPU gauge also sporadically jumps and instead of being at 2-5% when i first initially bought it.Sometimes it goes that...
Performance & Maintenance
the attached images says it all...
i don't know whats happening in my 7.... the aero theme was no longer available and i cannot connect to the internet..please help me...
General Discussion
Hard drive low pitch grumbling noise *sound attached*
Recentley my 1tb hard-drive has starting making these low pitched grumbling noises almost like a vibration when its being accessed. I notice it most when im defragmenting or gaming It does not happen when i defragment my other hard drive heres what it sounds like, fans quite loud but you...
Hardware & Devices
Steam Images Problem
Hello , I have been using steam for weeks since format.I was having no problem until yesterday.Steam Images( store images , avatars , other images , even in store.steampowered.com and gamespot.com ) are not shown.I dont know why. Can You help me out ?
Gaming
