#31
OK Try this. Open Control Panel, then Hardware and Sound then click the Playback tag. You should have one device that reads "Speakers". Has that got a green tick on it, if not right click on Speakers and choose "Set as Default device"
ya ya... i saw it... it is already the default device....
You may need to open the "Command Prompt" and execute:sfc /scannowTutorial:
After reading 4 pages of this thread, It looks like its an issue with the integrated audio (basically, the motherboard). Instead of replacing the motherboard, just get an external sound card and install it. It would be a cheaper option as well.
Good Luck,
Dinesh.
