Sound problem. Plz help.. images attached..
NRT
Power User
7:55 AM
Kerala, India
I've upgraded my computer... now a sound problem arises... I'm using bubbles as my screensaver set to 6 mins, after that in power options turn off monitor at 15 mins.. I've installed Adobe Audition, Winamp etc.. when i tried to play a song in winamp, it shows like the below attached image, opened audition: same problem, opened WMP: same problem... no sound from computer... i've checked speaker levels, while moving the slider, it shows nothing... plz help... is it a motherboard problem ??? :cry:
Windows 7 Ultimate 64-bit SP1AMD Athlon II X2 260 @ 3.2 GhzKingston 8.0GB Dual-Channel DDR3 @ 669MHz (9-...ASUS EAH 5450 - 1 GB
Assembled
Gigabyte Technology Co., Ltd. M68MT-S2 (Socket M2)
Kingston 8.0GB Dual-Channel DDR3 @ 669MHz (9-9-9-24)
23 Inch - DELL SP2309W
2048 x 1152
488GB Seagate ST3500418AS ATA Device (SATA)
450W
Iball - Standard Form - i8190
Stock Cooling
1 MB/Sec
Creative Inspire 2.1 Speakers, LITEON 24x DVD Writer
any help? :confused:
Assembled
2048 x 1152
450W
Stock Cooling
1 MB/Sec
Try to re-install your sound card drivers.Go to device manager and check if there are any yellow exclamation marks on sound devices.
Windows 8 Prointel i3 2.40 Ghz6 GB RAMIntegrated Intel HD
DELL
Windows 8 Pro
intel i3 2.40 Ghz
DELL inc
6 GB RAM
Integrated Intel HD
Realtek high definition SRS surround sound
1366*768
320 GB
1Mbps
no... the device manager has no yellow exclamation marks.. i've re installed the sound drivers... but sound is goin at irregular times...
Assembled
2048 x 1152
450W
Stock Cooling
1 MB/Sec
Are you using integrated sound card or is it an external one??If its the latter i suggest checking if sound card is seated properly on the MB.Otherwise maybe your sound card is failing.
DELL
Windows 8 Pro
intel i3 2.40 Ghz
DELL inc
6 GB RAM
Integrated Intel HD
1366*768
320 GB
1Mbps
integrated sound card...
Assembled
2048 x 1152
450W
Stock Cooling
1 MB/Sec
I remember not long ago when i build my desktop for the first time i had ASUS MB and on board sound card failed.If your MB is still under warranty i suggest to take it to ASUS repair center.
Or hold on others may have better suggestion.
DELL
Windows 8 Pro
intel i3 2.40 Ghz
DELL inc
6 GB RAM
Integrated Intel HD
1366*768
320 GB
1Mbps
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
Assembled
2048 x 1152
450W
Stock Cooling
1 MB/Sec
is it a sound card problem.. ?? or it cud b a virus ?? plz help... :confused:
Assembled
2048 x 1152
450W
Stock Cooling
1 MB/Sec
You said in your first post that you have upgraded your computer. Can you be more precise? What exactly have you upgraded the hardware or the OS?
Microsoft Windows 7 Home Premium 64-bit 7601 ...Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz8.00 GBIntel(R) HD Graphics 4000
ASUSTeK COMPUTER INC. P8H77-M
8.00 GB
On Board
Dell 24"
500w Corsair
Cooler Master
3 Fans
Logitech MK300
Logitech WOM
75Mb
Norton 360
Firefox, Opera, IE
  • Like
Reactions: NRT
ya... upgraded my hardware.....
Assembled
2048 x 1152
450W
Stock Cooling
1 MB/Sec
If not as listed in your specs, what is it now?
Gigabyte IF233
Avast! 8.0.1497
IE 11
yes.... its listed in the specs.... I'm on a surge of buying a new motherboard as u (dwarf) said to go with Gigabyte... but i want to assure its my ASUS' inbuilt sound problem (listed above)...
Assembled
2048 x 1152
450W
Stock Cooling
1 MB/Sec
Assembled
2048 x 1152
450W
Stock Cooling
1 MB/Sec
It could be either or both. I've no experience with VIA audio (all my systems have used Realtek), so it might be pertinent to see if a VIA audio user can offer any advice.
Gigabyte IF233
Avast! 8.0.1497
IE 11
Short of putting a spare PCI sound card in it is difficult to tell!
8.00 GB
On Board
Dell 24"
500w Corsair
Cooler Master
3 Fans
Logitech MK300
Logitech WOM
75Mb
Norton 360
Firefox, Opera, IE
i've formatted my computer atleast 3 times to get rid of this problem, of the thought of a virus... scanned with malwarebytes and found no infections though.. :cry:
Assembled
2048 x 1152
450W
Stock Cooling
1 MB/Sec
I doubt this is malware-related : it certainly points to a hardware/driver issue. has the sound ever worked on this system before? At which point did it stop functioning properly?
Regards,
Golden
Golden Mk. I.4
EVGA NVidia GTX 560 1024MB
Realtek Integrated
1920*1080 and 1920*1080
1*Samsung 840 EVO 120GB SSD;
1*OCZ Vertex 2 60GB SSD;
1*Samsung F1 SpinPoint 1TB;
Logitech G110
Logitech MX518
Have you tried the mundane things like, trying the speakers in the front speaker socket? Trying a headset in the front and back sockets? Trying your speakers in another PC if this is possible?
8.00 GB
On Board
Dell 24"
500w Corsair
Cooler Master
3 Fans
Logitech MK300
Logitech WOM
75Mb
Norton 360
Firefox, Opera, IE
