Solved Low sound volume
saulob
1:51 AM
I have one Sound Blaster Audigy 2 Value
Ok, I read that it's a driver problem.
But, I already tried both drivers available to my card, the one official from Sound Blaster (SBAX_PCDRV_LB_2_18_0011.exe) and the one from Daniel_K (Audigy_SupportPack_2_0.exe) and same low volume problem.
Still the sound is very low. Yes, everything is on maximum and the 'Communications' tab is on 'Do nothing'
Please, someone, help me :)
I'm using Windows 7 RTM.
Seven
Seven
Give this one a try,
SB Audigy Series Support Pack 2.5 (08/09/2009) - Creative Labs
He just posted it today,
Fixes and improvements:
- Workarounds a bug that unexpectedly resets the speaker configuration.
- Prevents an issue during installation on Windows 7/Vista that may result in low volume when certain enhancements are enabled.
- Really improves CMSS Headphone experience.
- Dolby Digital Live works on Windows 7.
- Updates all InstallShield setup scripts to support Windows 7.
- Fixes installation INI to properly install applications depending on the detected OS.
- Removes COM workaround for Equalizer, fixed by Creative.
- Adds workaround to a memory corruption issue preventing Equalizer from starting on Windows 7/Vista.
- Updates shared modules, responsiveness on certain applications is improved.
- Enables CMSS2 and Stereo Surround.
- Fixes 32-bit ASIO not working on Windows 7 x64.
- Fixes Encoder not available on Windows 7 x64 (related to fix above).
- Modifies default format on Windows 7 / Vista to 24-bit, 48kHz.
- Properly adds support for 64-bit OpenAL and 64-bit ASIO.
- Sets default speaker setting to 5.1 to properly reset configs to their defaults during install (fixes Bass and Treble leves not set to
The bolded bit sure sounds like what you are describing.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Have you configured the speakers in windows? I was having problems with movie sound until I set to DVD quality.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
GSkill Phoenix Pro 120GB SSD
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
I was having the same problem on my Vista machine, chev65.
Your picture .... "set to DVD quality" ... helped me on that machine! LOL Thanks ;)
Windows 7 Ultimate 32bit SP1
INTEL/D975XBX2
ATI Radeon HD 2600 Pro
Samsung SyncMaster 914v
1280 x 1024
One is not connected
Rocketfish 700 W
G.Skill Gigabyte Chassis
Standard PS/2 Keyboard
Microsoft PS/2 Mouse
DSL
Avira Internet Security
IE 11
ATI HDMI Audio
chev65.
Thank you very much. your tip fixed that low volume...
I got the new daniel_k driver and the same error, but, you fixed :)
I'm going to post right now on the Daniel_K thread in the Creative forum about this fix, ok?
Thanks.
Seven
Seven
Yes that one threw me off for a minute also, I put a movie in and no sound at all so I figured that was the one to play with, i'm not sure why it's not on DVD quality by default. Thanks for the rep.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
chev65.
Thanks.
Sure you can do that, I'm sure a bunch of other people are having that problem because the sound isn't set to DVD quality by default for some reason.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
thanks fixed my sound problem
windows 7 64 bitintel core i5 3.30GHz Quad Core6gbAMD RADEON HD 6450 1GB Dedicated
HP Pavilion p6795a
windows 7 64 bit
HP
6gb
ATI HIGH DEFINITION SOUND
LG
16:9 Hd
1TB
Fan
Wireless
HP wireless keyboard and mouse
fast enough
Beast Of A Machine!
sound still low
Thanks everybody, but the sound is still low. This is a major problem, dont you think? Can we expect a real solution from Microsoft? Thanks again,
marinildac
Windows 7 Home Premium 32 bitsIntel 2 Duo 7500 2,93 GHzKingston 4 Gbonboard
no manufacturer, this is a builted machine
Intel
Kingston 4 Gb
onboard
onboard
LCD 17LG
HD Seagate 250
Seagate external 250
DVD/CD LG
Is this for games? No games
what is this?
I dont know de manufacturer
It's not a "microsoft" problem - it's a SoundBlaster issue. Microsoft doesn't (or doesn't have to) make the OS work with SoundBlaster's, SoundBlaster must make their hardware/drivers work with whatever it's installed on.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
No it isn't. According to marinildac's specs he is using onboard sound, and I know Jacee is as well.
marinildac if you didn't also try the "16 bit, 44100 Hz" setting.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Thank you very much. Well, I did it weeks ago, and also installed the new Realtek stuff. Sound is now audible, but I wonder, is it enough...?
(oh, Marinildac is a she, a 63 y-o old Brazilian she... :))
Intel
Kingston 4 Gb
onboard
onboard
LCD 17LG
HD Seagate 250
DVD/CD LG
what is this?
Windows 7 Ultimate x64Intel Core i7 2600KG.Skill RipJawsX 8GB (2x4GB) DDR3 PC3-12800AMD/ATI XFX Radeon HD 6970
Desktop
Intel Core i7 2600K
ASRock Fatal1ty P67 Professional
WD Caviar Black 1TB
WD Caviar Blue 500GB
Crucial C300 64GB (SSD)
CM Silent Pro Gold 1000W
CM HAF X
Corsair A70
Thermaltake Tt eSPORTS Challenger Pro
Thermaltake Tt eSPORTS Black
i just keep 1 or 2 % sound it work like 100% something wrong
Windows 7 Ultimate 32bitpentium2gbonboard
intel
pentium
intel
2gb
onboard
HDD 250GB
no
chrome
