Can't get Rear Audio jacks to work While cable connected to front jack
NewW7User
8:33 AM
I am fairly new with W7 so please excuse my inexperience with this.
I have headphones connected to front headphone jack (Dell Inspiron 560 W7 Home 64). I want to have cable connected to rear jack (for speakers in other room). I can't get audio from the rear if anything is connected to the front jack. I do get about one second with the rear pink jack and the yellow jack - but not the green jack - but after one second it stops.
The sound card is RealTek High Definition Audio, driver from 10/09 Vers 6.0.1.5963.
Note that when making a similar connection to my XP machine the RealTek card/jacks do play in both front and rear at the same time.
I have attached screenshots of the Control Panel ->RealTek image (annotated with mouseover text) and the Volume->Properties image.
    W7 Pro 648G
    Dell XPS 8300
    W7 Pro 64
    8G
    Asus
    WD Elements, Samsung Story Station, Samsung EVO 860 / 870
    Logitech M310
    Avast, Malwarebytes, SUPERAntiSpyware
    Firefox, Avast Secure Browser
    Win10
    HP
    Win10
    external
    wireless
    Firefox, Avast
    Avast / Malwarebytes / Superantispyware
I do a lot of support on the Dell users forum. Dell uses a custom implementation of the RealTek audio, only the Dell RealTek audio drivers will work or work properly. Some models of the RealTek audio chip have the capability to do what you want and some do not, on others it's up to the PC/Motherboard vendor whether to implement certain functions or not. It may be possible but I don't recall seeing any posts on the Dell forum about this particular item.
Usually, the default setup is to mute the rear connected speakers when a headphone (or whatever) is plugged into the front headphone jack.
Here is the Dell on-line manuals for the 560/570 models
http://support.dell.com/support/edocs/systems/insp560mt/en/index.htm
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
This is as said, by design.
You may be able to switch off front sensing using the small icon just above the "analog" on your screenshot - this may solve the issue.
If not its a case of physically disconnecting the jack sensor inside the case, or the use of a splitter to connect both required outputs to the rear jack socket. Not eligent, put practical
    Ryzen 9 5950X, 3.8 - 5.2 MHz
    Asus Prime X570-Pro
    64GB [2 x 32GB] DDR4 3200MHz
    2 x 3840 x 2160 @60Hz
    Workstation Case [Matt Black]
    920 MB Down 50 MB Up
    Also run ...
    Nexus 7 Android tablet x2
    Samsung 10.2" tablet
    Wacom Expresskeys Remote
    Loopdeck+ Graphics Controller
    Shuttle Pro v2 Control
    Dell XPS 17 10750H
    Windows 11 Pro x64 Latest RP
    Intel I7 10750H 5.0GHz
    Dell XPS
    32GB [2x16GB] DDR4 2933 MHz
    nVidia GTX1650Ti 4 GB GDDR6
    Stock [Realtek] 4 Speaker
    3840 x 2400
    Stock - Active Fan Control
    Backlit + Various Logitech
    72 MB Down 18MB Up
    Also run ...
    10.2" tablet
    Sony Z3 Android Smartphone
    Shuttle Pro v2 Control Pad
    10TB NAS
Thank you fireberd and Barman58 for your replies.
At least I know that it is not something that I am doing wrong. It's just another case of B.A.D. (Broken As Designed) code, this time by Dell.
Thank you for your help - it is appreciated :)
    W7 Pro 648G
    Dell XPS 8300
    W7 Pro 64
    8G
    Asus
    Logitech M310
    Win10
    HP
    Win10
    external
    wireless
    Firefox, Avast
