Realtek HD Audio/Motherboard Not recognizing any Audio Devices.
  1. Posts : 6
    Windows 7 64-bit
    Hello,
    I'm gonna try and lay out my problem very simply, and then tell you what I have tried/done.
    PROBLEM: When I plug in Headphones, I can not hear anything, and in the playback devices, nothing is shown to be plugged in. This goes the same for my other audio device which is a bose sound dock (for ipod but I connect using a 3.5mm to 3.5mm cable)
    Okay, so here goes. When I first build the system and installed windows, i wasn't thinking much of the sound as i was installing updates and video card drivers and what-not. I did, at some point, connect the bose to the computer using the 3.5mm jack on the front panel of the computer. It worked fine, I heard the little sounds the computer makes when logging on. Since then I have had troubles with my network card and ran windows update and various other things.
    Now no sound works at all. When I realized this I tried:
    -Changing the actual front panel cable that is connected to the mobo from hd audio to ac 97 (and changing the setting in the bios)
    -Searched for many hours online trying many different solutions such as:
    -updating drivers
    -rolling back drivers
    Other things i've tried:
    -system restore
    -update bios
    -install audio drivers from mobo disc
    I have moved past being extremely frustrated and I now just dont know what else to do.
    I would greatly appreciate any feedback what so ever :)
    Ask me any questions you want
  2. Posts : 2,362
    Win7 H.Prem. 32bit+SP1
    Try this.
    Nvidia.pdf
    Then this.
    Realtek HD Audio/Motherboard Not recognizing any Audio Devices.-rr.jpg
  3. Posts : 6
    Windows 7 64-bit
    I don't have a nvidia graphics card. This won't work for me :/ (I tried anyways and the search resulted in no matches)
    Thanks anyways.
  4. Posts : 6
    Windows 7 64-bit
    I took a couple screenshots to show you guys what im looking at. Maybe it will help.
    Attached Thumbnails Attached Thumbnails Realtek HD Audio/Motherboard Not recognizing any Audio Devices.-screens.png
  5. Posts : 6
    Windows 7 64-bit
    Does no one have any input on this at all? OR any other forum I can go post this? I still have not resolved the issue.
  6. Posts : 6
    Windows 7 64-bit
    Still nothing??
  7. Posts : 12,012
    I notice your speakers are shown as not plugged in.
    Do you have speakers and can you currently get any sound from them, as opposed to headphones?
  8. Posts : 6
    Windows 7 64-bit
    I dont technically have any speakers. I have had sound, but I had only connected a 3.5m to 3.5m jack to (these.
    This was early on in my setup process. My guess is that through updating something somewhere it cause the sound to get messed up.
    The only thing i was trying to fix at the time was this wireless pci card. It wasnt working. I solved that problem when i found out the card was way too old.
