Realtek HD Audio/Motherboard Not recognizing any Audio Devices.
Scrubnub
3:55 PM
Hello,
I'm gonna try and lay out my problem very simply, and then tell you what I have tried/done.
PROBLEM: When I plug in Headphones, I can not hear anything, and in the playback devices, nothing is shown to be plugged in. This goes the same for my other audio device which is a bose sound dock (for ipod but I connect using a 3.5mm to 3.5mm cable)
Okay, so here goes. When I first build the system and installed windows, i wasn't thinking much of the sound as i was installing updates and video card drivers and what-not. I did, at some point, connect the bose to the computer using the 3.5mm jack on the front panel of the computer. It worked fine, I heard the little sounds the computer makes when logging on. Since then I have had troubles with my network card and ran windows update and various other things.
Now no sound works at all. When I realized this I tried:
-Changing the actual front panel cable that is connected to the mobo from hd audio to ac 97 (and changing the setting in the bios)
-Searched for many hours online trying many different solutions such as:
-updating drivers
-rolling back drivers
Other things i've tried:
-system restore
-update bios
-install audio drivers from mobo disc
I have moved past being extremely frustrated and I now just dont know what else to do.
I would greatly appreciate any feedback what so ever :)
Ask me any questions you want
Windows 7 64-bitAMD Athlon II X2 270 3.40 GHz4GB DDR3XFX Radeon 6790 1GB
Windows 7 64-bit
ASUS M5 A88-V EVO
4GB DDR3
XFX Radeon 6790 1GB
Western Digital "Caviar Green" 1TB 3.5in SATA
Corsair TX650
Cooler Master HAF 932 Advanced Blue Edition
Razer Lycosa
Logitech M110
I don't have a nvidia graphics card. This won't work for me :/ (I tried anyways and the search resulted in no matches)
Thanks anyways.
Windows 7 64-bit
ASUS M5 A88-V EVO
4GB DDR3
XFX Radeon 6790 1GB
Corsair TX650
Razer Lycosa
Logitech M110
I took a couple screenshots to show you guys what im looking at. Maybe it will help.
Windows 7 64-bit
ASUS M5 A88-V EVO
4GB DDR3
XFX Radeon 6790 1GB
Corsair TX650
Razer Lycosa
Logitech M110
Does no one have any input on this at all? OR any other forum I can go post this? I still have not resolved the issue.
Windows 7 64-bit
ASUS M5 A88-V EVO
4GB DDR3
XFX Radeon 6790 1GB
Corsair TX650
Razer Lycosa
Logitech M110
Still nothing?? :(
Windows 7 64-bit
ASUS M5 A88-V EVO
4GB DDR3
XFX Radeon 6790 1GB
Corsair TX650
Razer Lycosa
Logitech M110
I notice your speakers are shown as not plugged in.
Do you have speakers and can you currently get any sound from them, as opposed to headphones?
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
I dont technically have any speakers. I have had sound, but I had only connected a 3.5m to 3.5m jack to (these.
This was early on in my setup process. My guess is that through updating something somewhere it cause the sound to get messed up.
The only thing i was trying to fix at the time was this wireless pci card. It wasnt working. I solved that problem when i found out the card was way too old.
Windows 7 64-bit
ASUS M5 A88-V EVO
4GB DDR3
XFX Radeon 6790 1GB
Corsair TX650
Razer Lycosa
Logitech M110
