Front panel to motherboard connection
Bursal
8:41 AM
I want to connect a front panel HD audio to my computers but not sure what goes where on the motherboard headers. Just to clarify two completely different systems no connection apart from network.
The front panel lines are Bass, Centre, Gnd, Rear-R, Rear-L, Front-R, Front-L, Mic –L & Mic-R. No problems with Gnd, but that leaves the other lines.
The motherboard headers are:
On the Gigabyte motherboard the 2 mic and gnd are obvious but what lines do the ACZ_Det , FAudio_JD & Line2 L & R go to.
On the ASUS motherboard Port1 L & R, Port2 L & R, Sense_Send, Presence#, Sense1_Retur and Sense2_Retur.
Oh where is the naming convention for these things :banghead:
Windows 7 Ulimate x64, Windows 7 Pro x64
Hi Bursal, welcome to 7F! :)
Since you failed to fill out your System Specs, except that you are working with Gigabyte, and Asus MB's it took me a while to at least get you to where you need to go to find the information you are looking for.
For Gigabyte go to: GIGABYTE - Support & Downloads - Downloads - Motherboard
You will see that there are already a list of MB's, and you can download their manuals there, but if you don't want to go through at least 6pages I suggest you do the search.
To give you a look at what I found, and make no mistake. I have no idea if this is your board.
These pixs are from a GA-P41T-D3P User's Manual:
Descriptions to all the connections are below each diagram.
For the Asus it is a little different.
Go to: ASUSTeK Computer Inc. -Support- Drivers and Download
From there you can either automatically detect your MB or manually drill down for the manual of your board.
You already have the information you seek if you have the manuals to these boards
Originally Win 7 Hm Prem x64 Ver 6.1.7600 Bui...Intel i3 530 2.93GHz, 2933MHz 2 Cores 4 Logic...6GB of 1,333MHz DDR3 SDRAM32MB Intel Graphics Media Accelerator HD IGChip
Gateway H57M01 133 megahertz
1600 x 900 x 59 hertz
300watts.
Mid-Tower Desktop
Stock from Gateway
System Specs by Belarc.
Canon Pixma MG3222 Printer.
Hi Anak
Thanks for the reply. I have both of the motherboard manuals but the problem is I don't understand the different terminology, ie is the which pin matches which line as there is nothing similar in the names. Even the two motherboards use different terms.
The standard "HD Audio" front panel connection does not have surround sound options, on all that I've seen. Also, there should be a missing (no) pin that lines up with the HD Audio connector for the case front panel.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
300watts.
Mid-Tower Desktop
Stock from Gateway
Thanks for the replies and yes I am getting closer to solving the problem.
Both motherboards have HD audio, the ASUS has a VIA VT1818 8 channel HD Audio Codec which supports Jack-Detection, Multistreaming and Front Panel Jack-Retasking. The Gigabyte has a Realtek ALC889 codec which supports 2, 4, 5.1 & 7.1 channels and Dolby Home Threatre.
The front panel has four ports, Mic-in, Front_out, Rear_out and Cen/Bass, with a 9 line ribbon cable and individual connectors Centre, Bass, Front-R, Front-L, Rear-R, Rear-L, Mic-R, Mic-L and Gnd.
This is the info I have:
ASUS Header -Pin 1 - Port 1L, Pin 2 - Gnd, Pin 3 - Micpwr, Pin 4 - Presence#, Pin 5 - Port2R, Pin 6 - Sense1_Retur, Pin 7 - Sense_Send, Pin 8 - NC, Pin 9 - Port2L, Pin 10 - Sense2_Retur.
Gigabyte Header - Pin 1 - Mic2L, Pin 2 - Gnd, Pin 3 – Mic2_R, -AC_Det, Pin 5 - Line2_R, Pin 6 - Gnd, Pin 7 - Faudio_JD, Pin 8 - No Pin, Pin 9 - Line2_L, Pin 10 - Gnd.
From all of the reading I have done I assume that both headers have the same pin outs and that:
Pin 1 is Mic-L, Pin 2 is Gnd, Pin 3 is Mic-R, Pin 4 unknown (either Presence# or -AC_Det), Pin 5 is Front-R, Pin 6 is probablly Rear-R, Pin 7 is unknown (either Presence# or -AC_Det), Pin 8 is NC, Pin 9 is Front-L and Pin 10 is probablly Rear-L.
So I am left with front panel lines Centre, Bass, Rear left & right. I would assume that Sense1_Retur is Rear-R and Sense2_Retur is Rear-L, so now I am left with Bass and Centre.
Thanks again for your help.
Windows 7 Ultimate x64Intel Pentium Dual Core E5200 2.5GHz (3.77GHz...Corsair 4GB DDR2 (4x1GB CM2X1024-6400C4)Palit GeForce GTS 250 (1024MB)
Self built
Intel Pentium Dual Core E5200 2.5GHz (3.77GHz OC)
Asus P5Q-E
On Board (ADI AD2000B 8ch HD)
Samsung 32in LCD TV
1360x768
2 x 1TB Samsung 103SJ (Raid0)
2 x External 500GB Samsung 502IJ (NexStar 3 HD Enclosures)
550W Antec Neo HE 550
Antec P180
Xigmatex Red Scorpion CPU Cooler. 3x120mm Fans
Logitech MX5000 Laser (Combo)
ADSL2+ (avg 10 Mbps Down, 0.80 Mbps up)
Gigabyte GN-WP01GS 54g Wireless Lan Card
Looking at it again, if you compare the two pages you will find the pins for Line Out/Headphones, Mic and GND do match.
So at your own risk you could try the arrangement given in the second link for the ASUS board, although it does say
In most cases, you do not have to shift the wires in the header connector, as these wires have been arranged to match perfectly with the IFPA / AC97 pinouts.
Self built
Asus P5Q-E
Samsung 32in LCD TV
1360x768
Antec P180
It would be helpful to us (and you) if you supplied the model numbers of the motherboards, and the model of your case.
I take it from what you write that the case's front panel cable uses discrete pins rather than HD Audio or AC97 block connectors. Is that correct? (Some of the younger posters here may never have seen such a case, but I have one on hand like that. It's from 1997.)
Windows 7 Pro X64 SP1Intel Core I7-3930k16 GB Gskill DDR3-2133eVGA GTX680
homegrown
Intel Core I7-3930k
Asus P9X79 Pro
eVGA GTX680
Creative X-Fi Titanium
As PA246Q
1920 X 1200
Corsair Force GT, 120 GB
WDC 1.5TB Caviar Black
PCP&C Silencer 750 Crossfire
Silverstone FT02
Noctua NH-D14
cheap Logitech USB
Microsoft Intellimouse Explorer (old optical) USB
6Mb cable
Pioneer BDR-205
Samsung SH-203B
Monsoon 5.1 speakers
Thanks for erveryone who has replied, your time is much appreciated. I am beginning to think this will be one of those unsolved mysteries and will just use the USB ports.
The motherboards are Gigabyte - GA-880GM-USB3 and ASUS M4A87TD-EVO. The panel I would like to use is a 5.25" drive that I was given, no brand.
step 1 open the panel
step 2 unscrew the screws
step 3 remove the tray
step 4 remove the connector plate
step 5 ensure proper joining of wires and connectors
www.howtoinstallmotherboard.info
windows XP 2
windows XP 2
I am also having the same front dongle purchased from eBay from china. Even the supplier is not aware to which motherboard this dongle suits. So far I could not get any solution for this. It is a research project. This item is still sold on eBay. People are buying it due to ignorance.
windows 73.4 Ghz Pentium D1126
windows 7
3.4 Ghz Pentium D
Asus P5P800 VM
