Sound Popping
So, have you done anything recently that you think may have caused this? Added any new hardware, installed any new programs. Filling in your system specs in your profile might help too.
Windows 10 Education 64 bitAMD Phenom II X4 980 Black Edition Deneb 3.7GHz8GB 4GBx2 Kingston PC10600 DDR3 1333 MemoryZotac NVIDIA Geforce GT640 2 Gig DDR3 PCIe
Home Built
Thermaltake TR 620
Stock heatsink and fan
Logitech Wireless K350 Wave
80 Mbps Down 30 Mbps Up
Windows Defender
Internet Explorer 11
Well, as i said, i installed Win 7 again, so everything's new.
I'm checking the programs, but they're all of windows.
Fill up my syst. specs.
Windows 7 Ultimate x64Intel Core2Quad 2.66 GHz4GB 2GBx2 Kingston PC10600 DDR2NVIDIA Geforce 9500GT 512 MB DDR2 PCIe
Intelbras
Intelbras IE-G31TM7
VIA High Definition Audio
LG Flat Panel
1280x1024 x 2
Logitech Internet 600
2 Mbps Down
OK, when I asked you if it had done this from day one, or only just recently? You said recently. If you had just recently installed some new hardware or programs I would ask what they were and maybe ask you to remove them. When you re-installed windows did you do use the built in recovery utility or recovery disks to return the PC to factory condition? If yes and the noise is still there my guess is its a hardware fault.
Home Built
Thermaltake TR 620
Windows Defender
