Windows 7 Forums Search
Windows 7 - System sounds quieter than the rest of the audio
02-06-2012   #1
Windows 7 Ultimate Build 7100
My problem is that system sounds, such as error sounds, pressing the back button, and other such activities related to windows, are barley audible. However, sounds like music, game audio, and videos are playing just fine. I have checked my sound mixer and system sounds is cranked to 100%, along with everything else. This has started after installing my Logitech microphone on to the system, how ever I do not see how this can be causing the issue, I have tried unplugging it and the problem is persisting.
EDIT: Nevermind fixed it myself, I changed the option on communications to do nothing to system sounds if it detects that the system is being used for telephone (what?!) calls.
 System sounds quieter than the rest of the audio problems?
Similar Threads for: System sounds quieter than the rest of the audio
Recording Audio/ mic and system sounds...with headphones? Sound & Audio
Laptop will play system sounds but no other audio! Sound & Audio
Difference between system image, system rest and backup Backup and Restore
System Sounds Stopped & Internet Doesn't Play Audio! Sound & Audio
Audio Mid Recorder audio sounds thin and fraily Sound & Audio
