Solved Xonar ds sound volume fading in and out issue
Vaseer
12:47 AM
I just bough a xonar ds card to replace the onboard realtek 892. I had some minor issues with the cd that came with the soundcard, as it only had Vista drivers. Didn't realize at first and let it install. Sound did not work at all. I then uninstalled both realtek and vista drivers in safe mode and downloaded win7 drivers from Asus's website. I've got sound and gaming sound is excellent(especially in wolfenstein) but when i play music, no matter what i use, be it j river media center through ASIO or WASAPI, or if i use win media player, when the song starts, the volume fades in and out. For example when listening Nightwish - storytime at the begining the instrumental is made of high notes, sounds clear, but when the guitar and bass kick in, the volume fades down all together, and then the high come back at the normal volume. I'm not sure if i expressed it right, but i get this issue with most of the songs i listen. Some are .mp3 others .flac or .wma lossless. The issue is there regardless if i use headphones or speakers. Could it be due to the sound card, or would a win reinstall solve the issue? Thank you.
Running: AMD Athlon II X3, XONAR DS 7.1, Win 7 x64.
Windows 7 Ultimate x64AMD Athlon II X3A-DATA XPG Gaming Series V2.0 2x2GBAMD ATI RADEON HD 5570 OC to 750Mhz
Self-made
AMD Athlon II X3
ASRock 890FX Deluxe5
Asus XONAR DS 7.1
PHILIPS Brilliance C-line
1680x1050 16:10
Samsung Spinpoint F3 SATAII 1TB
The XONAR DS Audio Center is set to Audio Channel: 2 channels
Sample Rate: 192Khz
Analog Out: 5.1
Note: issue appears with both 192Khz and 44.1 Khz
Self-made
AMD Athlon II X3
Asus XONAR DS 7.1
1680x1050 16:10
ISSUE RESOLVED
Stupid ME. Never thought to actually check the mixer of XONAR DS AUDIO CENTER. It has a master volume and also individual volume for each channel. On default, each channel is set to the standard 100% (showing as 78% in the audio center). If you push those to max the card will amplify each channel above the 100% limit, causing the issue i described. All works excellent on 192Khz 24bit 5.1 output with WASAPI and ASIO with the mixer on default. Thanks and sorry for starting a useless thread. Oh, for future note to anyone who sees the thread. The XONAR DS does not have an EMI shield. I initially installed it on the PCI next to the graphics card. The cooler of the card was 5mm away from the sound card. I later switched the sound card pci with that of the tv tuner(the latter being farther away from the graphics). Apparently EMI is 0 or unnoticeable now. The graphics card in so close proximity was causing a bit of EMI(better said, the running engine of the cooler). As an advice, try to install your soundcard as far away from the graphics card as possible.
Self-made
AMD Athlon II X3
Asus XONAR DS 7.1
1680x1050 16:10
i have the same problem like you did with my xonar audio card, but i can't find that mixer you talk about. i downloaded the driver from asus, i installed the audio card driver from device manager by browsing it on my pc, it's now installed and working, however there is the bad fading sound issue.
where can i find this bloddy mixer ?
windows 7 ultimate x64
i just now finished sorting out my problem with my ASUS xonar d2x card, i have a 64bit system , so i natually downloaded the 64bit drivers for my system, well they did not work, i was getting very very low audio, so after many trials and errors, i downloaded the 32bit drivers for my card, and what do you know they worked pefectly. so if your having some issues with drivers i suggest to try the 32bit drivers because i did that now i have sound, they 64bit ones wouldnt even work correctly. so..... just thought i would tell you this so you save some time :D happy computing guys.
Windows 7 ProIntel i7 980x6 Gigs PatriotNvidea BFG Tech G Force 295 GTX
Myself :)
Windows 7 Pro
Intel i7 980x
EVGA X58 SLI LE
6 Gigs Patriot
Creative Sound Blaster Audigy
ViewSonic 17" < < old school
C: Velociraptor 10,000 RPM 300 gig
Storage- 1TB, 2TB
Corsair 750
Cooler Master Haf X Full-Tower , http://bit.ly/bQxsNq
Stock i7980 heatsink fan for now.
