MonkeyMadness
- Local time
- 12:06 AM
- Messages
- 11
I've got an Asus Crosshair V Formula motherboard that I couldn't get any sound on my Onkyo HT-R550 receiver via the onboard optical output (Win 7 Ultimate 64 bit OS) I was planning on getting a nicer sound card anyway, so I bought the Asus Xonar Essence ST.
Installed that sound card but alas, I still have the same problem.
Speaker and headphone outputs work, but no signal is recognized by the receiver via the S/PDIF. I know that the cable and receiver are fine, I still have my previous computer which is running Win XP and it has been sending audio via the same cable to the same receiver for years. It still works if I hook it up. It has an Asus M2N-SLI Deluxe motherboard and an HT Omega Striker 7.1 audio card. Both the onboard and sound card optical output work with the optical out to the receiver.
With my current computer the Win 7 "Sound" window displays signal on the audio meter when I play audio or when I use the "Test" function. But no signal is recognized by the receiver. I've tried every format and sample rate. I've uninstalled all drivers and reinstalled. I've used DH Driver Cleaner to sweep out all previous existing audio drivers. I've also had the onboard disabled since I originally installed the card. I've tried everything I can think of and manipulated all the settings in the Xonar Essence ST Audio Center software that are relevant. I think I've tried everything, but I'm hoping I'm wrong. I've submitted this to Asus technical, but it's been 5 days with no response, so I figured I post it here.
I've Googled the heck out of this for the last week and haven't found anyone with the same problem, or at least, none of the solutions were effective for me. This really should not be this difficult. It was practically "Plug & Play" with my previous computer. I'm strongly suspecting a Windows 7 issue, but I have no way to verify that currently. For what it's worth I'm using the only driver available that I'm aware of: Xonar driver 7.12.8.1794
Anyone with any suggestions or ideas? I'd greatly appreciate it.
Windows 7 Ultimate x64AMD Phenom II X6 1100T Black Edition 3.3 GHzG.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin ...2 Asus GeForce GTX 560 (SLI)
- Me
- Windows 7 Ultimate x64
- AMD Phenom II X6 1100T Black Edition 3.3 GHz
- Motherboard
- Asus Crosshair V Formula
- G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 1333
- Graphics Card(s)
- 2 Asus GeForce GTX 560 (SLI)
- Sound Card
- Asus Xonar Essence ST
- Monitor(s) Displays
- Acer P243WAid Black-Silver 24" HDMI Widescreen LCD
- Screen Resolution
- 1920 X 1200
- Hard Drives
- 1 Mushkin Enhanced Chronos Deluxe 120GB SATA III (SSD)
1 WD 500 Gb 7200 rpm HD
1 Samsung 750 Gb 7200 rpm HD
1 Seagate 1 Tb 7200 rpm HD
- PSU
- Corsair HX850
- Case
- Lian Li PC-B10 ATX Case
- Cooling
- Antec Kuhler H2O 620 Liquid Cooling System
- Keyboard
- Logitech Y-BH52
- Mouse
- Logitech MX Revolution Cordless
- Other Info
- Headphones: Ultrasone HFI-580
Desktop Speakers: Creative Gigaworks T40 Series II
