Windows 7: Sound Recorder Not Finding Existing Recording Devices
15 Feb 2012   #11
Windows 7 Professional 64 bit
thx for pointing me on the install instructions. Turned out I already had done a manual .exe start (not through self-extractor) before ... so I'll take your next great tip with the specific Dell Laptop Forum now ... as a multi Dell user I didn't ever knew in all this years such a forum already exists under Dell ... that's cool to know about it now ! Thx firebred. I'm a late bird.
Frank
15 Feb 2012   #12
how can I login at the forum to create a new topic ? Can't find it. All I found was Join so far to setup a new account, but I see it's a dell url and I already have my dell account.
15 Feb 2012   #13
Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit
Citrus Co, FL
You may be able to use your user id/password for your Dell account. If it doesn't work you will be able to register.
Here is a different link, it may work better. Home - Dell Community
There is a place to sign in. You can then access the different forum sections from the Support Forums dropdown menu.
 Sound Recorder Not Finding Existing Recording Devices problems?
Similar help and support threads for: Sound Recorder Not Finding Existing Recording Devices
Rear'Microphone' and 'Line in' Sound recording devices are unavailable Sound & Audio
livestream recording in sound recorder Sound & Audio
Search isn't finding some existing files General Discussion
Help! Recording audio with my sound recorder Sound & Audio
How to record a crisp clear recording using windows sound recorder? Sound & Audio
