Sound Recorder Not Finding Existing Recording Devices
Frank1000
10:14 PM
Hi, I can’t get my sound recorder reliably working. Each time there is a hassle to get it back running and sometimes it never finds a recording device although my laptop has a soundcard with stereo mix and an internal mic. I had both already working, recording from Stereo Mix and recording from Internal Mic., but I often have to re-estavblish a setting. Rt now although I select any recording device it’ll give me a “no device found” warning. If I plaback a file everything works fine, but the Sound Recorder can’t record it today.
Any clarification highly welcome.
Thx,
Frank
Windows 7 Professional 64 bit
One thing that stands out is the Internal mic is being identified as the "default communications device".
The external mic marked as ready normally indicates an external mic is connected (via the microphone input jack).
First thing, reinstall the PC vendor's sound driver. Do not use drivers from other sources as many times they do not work or do not work correctly. It looks like there is a corruption in the audio drivers with the status you are seeing for the devices.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
thx for reply firebird. Ya the communication device seems to be for apps tagged as phones or chat or such ... skype etc. .
I've checked the driver, but it's up to date. The Stereo-Mix stays "unavailable" regardless if I unplug the M-Audio FW 410 or not, even after restart without M-Audio.
Aha! A little "tidbit" that was not noted in the original post, the MAudio unit (I have a home recording studio using Sonar X1 and Pro Tools MP9). When I have my recording interface device connected, Windows detects and sets that at the default recording and playback devices. I've never used the Windows recorder but it may not be able to detect/use the MAudio unit as a recording device. My primary recording unit is a Roland Octa-Capture that I use with Sonar. I have an MAudio Fastrack Ultra 8R that I use with Pro Tools and is a backup for the Roland if needed.
Using Windows to search for software is not what is needed. You need to go to the PC vendor's site and download and install the driver they have for Win 7 and your PC model number. What is actually installed now may not be the PC vendors version of the IDT driver.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
tried it with the driver offered in the dell support page for my computer, it rolled the driver back to an earlier version, but there it didn't have a stereo-mix any more and I updated it back again for now. + the stereo-mix isn't even coming back with the re-installed up to date driver version ... seems to me you just need to deal with device management to be back in the dark age of ancient pc times.
Another surprise, you have a Dell. I do a lot of support on the Dell forum (I am one of the "user staff" since 2002) and we have found that non Dell drivers either do not work or do not work properly in almost all cases.
What model laptop do you have? (Fill in the My System Specs).
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
I have a Dell Vostro 1720 from 2009
You need to use the Dell SigmaTel driver, not the later IDT drivers. The Driver listed is for Vista 32 and 64 bit but it's also Win 7 compatible. Dell does not officially support Win 7 on this model, but the Vista drivers will work OK in Win 7. Drivers and Downloads | Dell [United States]
After you install the Dell SigmaTel driver go to the Recording panel and RIGHT click in a blank area and then click to show disabled devices and also disconnected devices and see if the System Mixer shows up.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Hi firebred, thx for the advanced help! I downloaded and started installing it, but it gives me an error, even if I restart the computer:
Make sure you follow the Dell install instructions. There are install instructions on the Dell download.
You may have to uninstall the newer IDT drivers first.
Also consider posting this problem on the Dell Laptop hardware forum section so those more familiar with Laptops can work on this. I mostly do desktop hardware support.
Here is the Dell Laptop Forum. You will have to register to post. Laptop - Dell Community
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
thx for pointing me on the install instructions. Turned out I already had done a manual .exe start (not through self-extractor) before ... so I'll take your next great tip with the specific Dell Laptop Forum now ... as a multi Dell user I didn't ever knew in all this years such a forum already exists under Dell ... that's cool to know about it now ! Thx firebred. I'm a late bird.
Frank
how can I login at the forum to create a new topic ? Can't find it. All I found was Join so far to setup a new account, but I see it's a dell url and I already have my dell account.
You may be able to use your user id/password for your Dell account. If it doesn't work you will be able to register.
Here is a different link, it may work better. Home - Dell Community
There is a place to sign in. You can then access the different forum sections from the Support Forums dropdown menu.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
