Popping noises over headphones/speakers at F/B panel !!! HELP!!!
Hello. I have these specs
-Asus M5A78L-M/USB3 - > Out of Stock ;/
-AMD Phenom II X4 955 3.2GHz 8MB cache Black Edition - > Out of Stock ;/
-ALPINE 700W PSU - > Alpine 700W Silent PSU with 120mm Red Silent Fan 24+4 Pin Intel v2.03 Enhanced +12V - Scan.co.uk
-Corsair RAM 2x2GB / 4GB 1600MHz 1.65v Dual Modules - > Corsair Memory XMS3 4GB DDR3 1600 MHz CAS 9 XMP Dual Channel Desktop - CMX4GX3M1A1600C9 - Scan.co.uk
-Gainward nVidia GTX 550Ti Golden Sample / GS - > Gainward GeForce GTX 550 Ti 1024MB Golden Sample NVIDIA Graphics Card - 426018336-2043 - Scan.co.uk
-Pioneer DVD - > PIONEER DVR-S19LBK DVD Writer, SATA, Labelflash, Retail - Scan.co.uk
-Samsung Spinpoint F3 HD103SJ - > Review - Samsung Spinpoint F3 1TB Review | bit-tech.net "same price as when I purchased it"
-Heatsink - > Coolermaster Vortex Plus CPU Cooler - RR-VTPS-28PK-R1 - Scan.co.uk
-Case - > Xclio / Meridian Technology Godspeed Two Full Black Mid Tower Computer Case - Scan.co.uk..
From the very beginning I had sound delay problems "note that I haven't got any speakers, been on my headphones" but I were on XP OS... then I went on W7 and delay stopped...perfect...great...wohooo. Eventually I bought speakers which are Logitech X-530 5.1 and I started to hear some kind of popping/clicking noises constantly "it's the same noise when you power ON your speaker into a power socket" and now it's even more of those weir sounds... Went with my 1.)motherboard with 2.)CPU and 3.)RAM modules on it only to the store where I bought them from.... told me that it might be 'cause of thermal paste which somehow got onto CPU's socket and CPU's ping but not 100% sure so I had to leave my motherboard to be cleaned up and got told to wait for 28 days..Couldn't wait for that long so I bought another exactly the same motherboard.. Well I got back home cleaned up the CPU to a perfect / mint condition.. joined everything together STARTED , well what do you know..SAME PROBLEM...then I tried my friend's same CPU as mine's ...... SAME PROBLEM "AGAIN"...Then I tried different RAM modules...SAME """"AGAIN"""""....So I don't have a clue what the hell is happening ? Tried re-arranging parts with my friend's ones and no positive results. Please help / suggest something I could do...
Forgot to mention, when I bought new motherboard I've also bought ASUS Xonar 5.2 sound card just in-case and same noises goes through it as well ;/
