Creative Sound Blaster X-Fi Xtreme Audio PCI - microphone problem
blackspear
10:25 PM
Hello there. Yesterday i've installed this sound card and everything works fine but no microphone. I can see it in control panel but it doesn't work. Mic is fine as i was using it before. I have Win 7 64bit.
If you have any idea what can cause the issue please help, if nothing will work i will simply send it back to shop ;/
Win 7 64
Win 7 64
What programs are you running to test it?
If your just not hearing yourself, in windows then it's the option there for listen to what you hear.
win 7 pro x64AMD [email protected]16gb G.Skill RipJaws 1333mhzTri Sli MSI GTX 470
win 7 pro x64
MSI NF-980a
Tri Sli MSI GTX 470
Audigy
View Sonic G220f
2046x1536
SATA
Raid0-3x64gbSSD-500-640-1TB
Corsair TX950
CM 932KWN3
Corsair H-50 2kP&P
Microsoft
G9x
25mb/4mb
I was checking it by windows microphone set program and TS
Win 7 64
Win 7 64
What i did now is turn on my audio card on MoBo and mic is working there. I could leave it like this so i have good sound from SB and working mic on old card but its not how it should be...
Win 7 64
Win 7 64
