Realtek HD detecting rear speaker as side (5.1)
Ive just recently switched from vista64 to windows 7 64.
The thing is that im using logitech X-540 5.1 speakers but realtek HD is detecting my "rear" speakers as "side" speakers when I select the 5.1 option. Same thing happened in vista too.
The only way round this to select the 7.1 option and disable the "side" speakers and hence I can use "rear". The sound from the "side" speakers then comes from the ones in the front in the testing.
Now the problem is that when I play games/movies in 5.1 it probably detects my system as a 7.1 and some sound will be missing.
So how can I use the 5.1 option and keep my surround speakers as "rear" and not "side".
Thanks in advance,
P.S. Buying a new soundcard isnt an option for me.
