New Diamond Xtreme Sound 7.1/24bit (XS71DDL) - no sound.
JaimeZX
11:53 AM
I've tried installing and reinstalling and downloading and redownloading the drivers... the BEST I've done is to have loud pops and clicks come from the speakers.
* Shut down the computer
* Installed card
* Plugged speakers into card
* Started computer
* Disabled onboard sound in the BIOS
* Booted into W7x64
* Downloaded drivers from DiamondMedia website
* Installed / rebooted
* Nothing
** By nothing I mean (no sound and) that when I open the sound controls in Control Panel, the green level meter that should be dancing when sound is playing does nothing. Neither "Speakers" nor the Digital/Optical out.
* Looked elsewhere for drivers
* Downloaded / installed / rebooted
* Nothing
* Repeat the last three steps several times
* Read a different thread on this forum recommending to run the installer as Administrator.
* Still nothing
* Sigh loudly and start writing this post.
Dunno where to go from here. According to the C-Media website, this card should be the CMI8768+ chipset. Yet I get nothing but pops and clicks. :(
Edit: Forgot to mention that in the control panel the level meter bounces when I make noise still. (Webcam microphone.) FWIW
W7 Home Plus x64AMD Athlon x64 5000+4GB Corsair XMS2 (DDR2 6400, 2048x2)Onboard
PC clone
W7 Home Plus x64
Asus M2A_VM
Onboard
Onboard
Samsung 206BW
750.1 GB ST3750640AS Seagate
Just-PC ATX-350-12
Blue
Like, 5 fans
Bizarre update. I wanted sound so I re-enabled the onboard sound and moved my speakers back there. In Control Panel, when I play a test sound now, the level meter in (onboard) speaker jumps, but so does the one for C-Media! (But if I plug the speakers back in there... still nothing.)
PC clone
W7 Home Plus x64
Asus M2A_VM
Onboard
Onboard
Samsung 206BW
Just-PC ATX-350-12
Blue
Like, 5 fans
Windows 7 Ultimate 64 bitAMD Phenom II X4 965 Black EditionGSkill 4 X 2 GB PC 8500XFX Radeon HD 6790 D
Custom built
Gigabyte GA-MA790X-DS4
On board RealTek HD
Dual monitors:Samsung SyncMaster S20B300
1600 X 900
Seagate Barracuda 1TB (primary)
Seagate Barracuda 2 X 320 GB
Ultra X4 750 watt fully modular
Thermaltake Overseer RX 1 full tower
Core-Contact 92 mm CPU Cooler
Logitech G510
Razor DeathAdder
50/5 Mbps UL/DL
Optical: Super Muliti DVD burner w/lightscribe, Hauppauge WinTV HVR-1800
I cant find anything on the website about a 24 bit sound card.
Custom built
On board RealTek HD
1600 X 900
Logitech G510
Razor DeathAdder
50/5 Mbps UL/DL
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Thanks fellas. Yes, I have the latest driver from the website. It calls it the "CMI8768+ driver for Windows 7" so should be okay there...
Any other thoughts?
Thanks again.
Edit: Having to put < br > after each line sure is annoying.
PC clone
W7 Home Plus x64
Asus M2A_VM
Onboard
Onboard
Samsung 206BW
Just-PC ATX-350-12
Blue
Like, 5 fans
