Sound card or not to sound card, that is the question?
badger906
I'm a badgerhollic!
1:29 AM
United Kingdom
Right chaps (and chappets)
I might be in the market for a sound card.. but im not sure if i need one :p
I have a set of Roccat Kave 5.1 headset and use it off my ASUS P8Z68's built in audio.
I only use my rig for gaming, and nothing else.
I have tried doing research as always with new purchases, but you get such a mixed bag of answers when it comes to sound cards.. "they are amazing so much better than on board" "dont waste your money, on board is fine unless your a music pro" ect...
soo do i need one? (i want one if i need one lol)
Budget is about £100
Been looking at the likes of Asus Xonar D2 Soundcard - 7.1 Ultra Fidelity With.. | Ebuyer.com
but not sure if me a mear mortal with normal ears will notice the difference between that, onboard or something half the price!?! :geek:
Windows 7 Ultimate x64, & Mac OS X 10.9.2Intel Core i5 2500kCorsair Vengence 8gb 1866mhzNvidia GTX 770 OC
Built by badgers!!!
Intel Core i5 2500k
Asus P8z68 LE
Nvidia GTX 770 OC
2x ASUS LED 22" IPS
3840x1080
240GB Crucial M500 SSD
120gb Corsair Force 3 SSD
1TB Western Digital
Corsair HX650w Modular
Corsair Air 540
Corsair H60 Push/Pull
Corsair K70/ Logitech G27 wheel
Saitek R.A.T 9
Too slow!
AMD fusion E350N Home server-Windows Home Server 2011 (also made by badgers!)
2011 Macbook 2.4ghz Core2Duo, 4gb ddr3, 120gb Ocz Vertex SSD
I'd guess your 100 pounds would be better spent on better headphones. That would stand a better chance of making an audible difference.
Not necessarily better, but different. Just like different speakers.
When you combine "golden ears" with the placebo effect and typical Internet babble, you are in a spot--as you are finding out. You'd have to experiment to find out, and of course you can't easily do that with new hardware.
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
lol i only purchased the kaves last week after much research and reading reviews lol. seemed to get a good write up as being one of the best surround sound head phones for gaming :( soo dont wish to replace them yet lol.
Its not the case that my current head phones dont sound good, they sound amazing!! ive had loads of gaming headsets over the years and ive not had a better sounding pair, i just thought i could take that step even further.
but your right on the placebo effect i guess, i just like buying new stuff for my rig lol
Built by badgers!!!
Intel Core i5 2500k
Asus P8z68 LE
Nvidia GTX 770 OC
2x ASUS LED 22" IPS
3840x1080
1TB Western Digital
Corsair Air 540
Saitek R.A.T 9
Too slow!
Another thing:
Human memory for sound is terrible. Few people can distinguish between 2 adjacent keys on a piano if they are struck a minute apart.
So if you install the new sound card, how would you know it sounded better--or worse? You wouldn't be able to accurately remember what the old sound card sounded like.
But you'd probably not want to admit to buyer's remorse, so you'd tend to favor the new one because you just blew 100 pounds on it.
Then if someone secretly switched you back to the old soundcard, you probably wouldn't notice that either.
How we respond to sound is very peculiar.
1600 x 900
Antec Solo II
Pale Moon
lol you remind me of my old physics teacher :D (thats a good thing) he had a way of getting things across to me!
thank you for your clear and well defined explanation/help :geek: kudos as per usual!
Built by badgers!!!
Intel Core i5 2500k
Asus P8z68 LE
Nvidia GTX 770 OC
2x ASUS LED 22" IPS
3840x1080
1TB Western Digital
Corsair Air 540
Saitek R.A.T 9
Too slow!
MS Windows 7 Home Premium 64-bit SP1Intel Core i5-2320 @ 3 Ghz / Intel Core i5 @ ...8.00 GB / 6.00 GB Dual-Channel DDR3 @ 532MHzSapphire HD 6670 AMD / ATI Mobility Radeon HD...
ADVENT / Dell Inc.
Intel Core i5-2320 @ 3 Ghz / Intel Core i5 @ 2.67GHz
ADVENT / Dell Inc. (CPU 1)
Sapphire HD 6670 AMD / ATI Mobility Radeon HD 5650
BenQ G2222HDL 21.5-inch Widescreen LED Back-Light Monitor
1980 x 1080
1.5 TB / 640GB (SATA)
Dell AC/DC Power Adapter
ADVENT / Dell Inspiron 15R
Microsoft Cooling Base
Logitech MK260 Wireless Keyboard
Logitech Wireless Mouse M310
Sennheiser HD 202 / Koss Porta Pro Stereo Headphones
Asus's onboard is it a realtek or via? Well, indeed it is very dependent on the listener, but from own experience, dedicated cards sound cleaner, better, and i don't know how to explain but gives you the ideea of reality. Sounds real. If you have high-end headphones, i would also buy a dedicated card. Try a Xonar DX, or DS if you're not into recording. The D2 is excellent if you can afford it. If you've got a friend that uses a dedicated card, take yhour headphones and test them there. You'll be able to tell if it will actually help for you or not. As said, it's very dependent on the listener
Windows 7 Ultimate x64AMD Athlon II X3A-DATA XPG Gaming Series V2.0 2x2GBAMD ATI RADEON HD 5570 OC to 750Mhz
Self-made
AMD Athlon II X3
ASRock 890FX Deluxe5
Asus XONAR DS 7.1
PHILIPS Brilliance C-line
1680x1050 16:10
Samsung Spinpoint F3 SATAII 1TB
All of the above. Another description would be dead, flat and lifeless. Just tested the Realtek ALC892 on mine and there is a very noticeable difference in music (not as much, but definitely there) and games (very noticeable). I will say that it is much better than it used to be even from a few years ago, but it still has a long way to go to sound as good as a dedicated card (and not some cheap $10.00 card).
Or even a decent set of speakers. A 2 cent DAC on onboard just can't compare to the DAC's used on sound cards. Most that say onboard is "good enough" either have never heard the difference, or are using equipment that won't sound any better no matter what it is hooked up to.
And now off to uninstall and disable the onboard once again.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
10 dollars won't do it but let's not get people scared. Anything equivalent or above Asus XONAR DS will offer a very noticeable difference, and should provide HI-FI sound
Self-made
AMD Athlon II X3
Asus XONAR DS 7.1
1680x1050 16:10
